GL-5 Gear lube
Buck D.
11-27-2005 13:18:07
I was looking through the archives about GL-5,and it seems most people say it is hard on JD transmissions.I just put 7 gallons in my G today.Should I drain it back out?
Buck D.
11-28-2005 04:14:50
 Re: GL-5 Gear lube in reply to Buck D., 11-27-2005 13:18:07
Thank you all for your help. I feel better about leaving it in the G now . The stuff that I drained out(over a 3 week period) was very nasty.A little water did come out first.Most of the rest was a very heavy,very black,tar like stuff.Probably 1948 vintage.I poured diesel fuel through a few times,but did not put the plug in and run the tractor as indicated in the operators manual.I'll leave this lube in for now,and change it next fall.Thanks again.
Duane Larson
11-27-2005 18:28:32
Wes,
A nice explanation of the use of the different GL grades by Brad Jordan, a chemical engineer from Shell, can be found at
Link
That article notes that most GL grades using EP additives now use inactive sulfur compounds to reduce/eliminate acid formation (as Frank noted) and that fact,together with the increased reduction in gear-to-gear contact, would indicate to me that today's GL grades above 2 which use EP additives would be ok for our transmissions, as long as we stick with a major manufacturer.
Information and applications of the various grades of GL 1-5 (Gear Lubricant) can be found at
http://kenoanyag.mol.hu/english/products/l...ikkei/doc123807
Duane Larson
11-27-2005 18:30:31
 Re: GL-5 Gear lube in reply to Duane Larson, 11-27-2005 18:28:32
Oops - meant to address the response to Buck, not Wes.
Wes Storm
11-27-2005 15:51:27
You can buy GL 1 at NAPA for about $28.00 a 5 gallon bucket. That way you do not need to worry about seals or a acid base forming with the moisture that is inherrent to cast iron setting in a unheated barn.
Wes
Buck D.
11-27-2005 16:02:59
 Re: GL-5 Gear lube in reply to Wes Storm, 11-27-2005 15:51:27
Hi Wes, That would have been a good idea had I not spent $102.00 on ten gallons of GL-5 and then put it in my tractor before I learned of these possible problems.Thanks for your input.
JGC
11-27-2005 15:47:36
I am not familiar with the "G" transmission, but my "D" transmission has very little bronze or brass - the metals at risk. The bushings in the reverse gear are about the only bronze parts in the transmission.
I bought 140 weight gear oil from a local lube distributor. I had read posts about GL-1 and GL-5 but didn't actually check what GL rating it was. No problems so far.
Jon
F-I-T
11-27-2005 14:40:46
Buck:
The only real concern up to now been that GL-5 has increased extreme pressure additive packages, and for years those EP packages worked because they used Chlorine and Sulfur for bases. If that CL or S was the "available" variety, then it could, if left to contact water that entered the gear case via rain water or condensation, form an acidic by-product, which could harm Bronze or Brass.
But, if you park it inside and the risk of water intrusion is minimal and you promise yourself to drain and flush it if it ever should get water in there (which you should do no matter what oil you use), then like G-Man says, it's got to be better that then who-knows-what it had in there before.
P Browning
11-27-2005 14:10:18
Buck D -- Here's what Illinois division of FS has to say about it;
"(1) Meets or exceeds Jhn Deere JDM J11E specs, and (2) Recommended For Use In All applications requiring GL-5 gear lubricant protection. Automotive differentials, manual transmissions, final drives, heavy-duty trucks, construction equipment, farm machinery, and many industrial applications."
From what I have viewed so far, the product should do very well for you. (PatB)
G/MAN
11-27-2005 14:04:17
I don't know that it's ever been said that it's "hard" on the transmission, it's just not the recommended lube and has different properties. I've read lots of times where guys have said the trannies are noisier with GL-5 than GL-1. Unless your's is noisier and it's really an issue to you, I'd leave it. Nice clean, fresh GL-5 has got to be much better than the half-water/half who knows what a lot of these old tractors have ran on for the last 3 or 4 decades. Unless I were doing a last-bolt restoration replacing every gear and bearing, I wouldn't worry about it too much. Old gears and bearings with some wear on them are simply going to make some noise, particularly the straight-cut gears used in Deeres.
