anti freeze
kenneth kirby
11-27-2005 13:09:56
can anyone tell me how many quarts or gallons antifreeze it would take for an A John Deere?
leon
11-27-2005 17:18:19
 Re: anti freeze in reply to kenneth kirby, 11-27-2005 13:09:56
I realize this isn't what you ask but I'd sure think twice before I put antifreeze in it especially if it has a paint job you value or if it's not had antifreeze in it before. Then if you do put it in, use only the old style green type ethylene glycol. The new pink stuff is hard on copper. Antifreeze gets through cracks and seeps where water never did, and when it seeps through it discolors paint terribly. Also, if it gets into the crankcase oil, goodby bearings!
Bob
11-27-2005 18:46:37
 Re: anti freeze in reply to leon, 11-27-2005 17:18:19
Heck of it is, though, a "ventilated" block or radiator tank is even MORE unattractive than a stain on the paint!
leon
11-28-2005 05:11:02
 Re: anti freeze in reply to Bob, 11-27-2005 18:46:37
Sure do agree with that! However, my two-cylinder's have drain plugs and since it's only once a year I that put them to bed for our very cold winters, I can remember that much.
Bob
11-28-2005 08:47:19
 Re: anti freeze in reply to leon, 11-28-2005 05:11:02
Leon,
If you can remember to drain everthing, you haven't got enough tractors! (Just josh'in 'ya!)
JGC
11-27-2005 16:09:58
My I&T manual says 9.25 gallons for serial number range 499,000 to 583,999 and 8.5 gallons for serial numbers 584,000 and up.
Jon
zr
11-27-2005 16:05:23
Be sure to pre-mix the antifreeze, especially if your tractor has no water pump. Thermo-syphon systems don't work so good with only ethylene glycol in the engine block.
Paul from MN
11-27-2005 13:58:11
On my 44A 9 1/4 Gallons.
