Is a 5303 powerful enough for round bailer???
Matt Wedeking
11-27-2005 12:24:48
Is a new John Deere 5303 powerful enough to handle a round bailer? I think the tractor is 55 HP. Would the weight of the bail matter Thanks!!!
barnrat
11-28-2005 06:11:51
 Re: Is a 5303 powerful enough for round bailer??? in reply to Matt Wedeking, 11-27-2005 12:24:48
The guy who bales my bedding hay runs a JD 2520 and JD 335 round baler(4x4 High density bales). He has no problem getting around on my hilly farm. He uses a 2940 4wd only when he makes silage bales, uses the 2520 when ever he can to save on fuel and it's more nimble.
idontno
11-28-2005 05:26:35
No....It will not run a 535 JD baler.My 75 hp. will hardly pull it.Small 4 ft baler it might...But you won"t go to fast...idontno
Matt Wedeking
11-27-2005 13:32:04
It will be on flat ground. I don't have a round bailer yet but want to be able to make 1500 pound bales.
buickanddeere
11-27-2005 13:15:05
Try a 6403, 6603, one of the 6000 15 series or even a 5105 with M4WD. A two wheel drive farm tractor is becoming a thing of the past.
leon
11-28-2005 05:14:10
 Re: Is a 5303 powerful enough for round bailer??? in reply to buickanddeere, 11-27-2005 13:15:05
I'd think that in the long green line newer stuff, a MFWD, 4 cylinder engine 5000 Series tractor would be about as small as you'd want to go.
leon
11-27-2005 12:51:51
I think that if you took it easy you might have power enough, but especially if you're on hills and/or have a baler that makes really big bales , tractor weight sure could be a problem. By definition you have no MFWD to help out. A bigger horse would be a better bet.
G/MAN
11-27-2005 12:59:30
 Re: Is a 5303 powerful enough for round bailer??? in reply to leon, 11-27-2005 12:51:51
I tend to agree. If you're farming table-tops, you'd probably be okay up to a midsize baler. If baling on hills, especially on some nice slick native or prairie grass, I'd want more tractor.
G/MAN
11-27-2005 12:49:39
How big of a round baler? Should be plenty for a smaller unit, but might have its hands full running something like a 535 or 567 baling up and down big hills.
