antifreeze
kenneth kirby
11-27-2005 11:26:16
would like any info on amount of antifreeze I should use in my A John Deere
Bob
11-27-2005 11:48:01
 Re: antifreeze in reply to kenneth kirby, 11-27-2005 11:26:16
Use 50-50 pre-mix, or mix the water and antifreeze BEFORE pouring in the tractor, assuming this is a thermo-syphon system.
G/MAN
11-27-2005 11:35:56
How cold does it get there? A 50/50 mix of quality ethylene glycol antifreeze and soft or distilled water will provide about the best freeze protection and minimize corrosion. Several companies, including Deere, are making premix coolants that you just dump in. Deere's isn't cheap, but it's a 5-year/5000-hr coolant made for heavy-duty applications. Probably overkill on and old tractor, but it's sure handier than dumping in a gallon of water, a gallon of A-F, etc.
zr
11-27-2005 16:10:18
 Re: antifreeze in reply to G/MAN, 11-27-2005 11:35:56
If you must have pre-mix, you can get it at Dollar General.
G/MAN
11-28-2005 10:15:45
 Re: antifreeze in reply to zr, 11-27-2005 16:10:18
And you'll get coolant of Dollar General quality.
