Brass washers in rebuild gasket set
Doug L.
11-26-2005 17:07:14
I got a gasket rebuild set from Yestersdays tractor for a B and was wondering where the 10 brass (maybe nickel) washers go. They look like they are about 9/16 and go on the head studs somehow. I hope not between the head and block because I put that on already with just the head gasket supplied. Thanks
44 Diesel Tech
11-26-2005 18:10:56
 Re: Brass washers in rebuild gasket set in reply to Doug L., 11-26-2005 17:07:14
Washers go under head stud nuts. They act as a lubricant.
Doug L.
11-26-2005 20:21:34
 Re: Brass washers in rebuild gasket set in reply to 44 Diesel Tech, 11-26-2005 18:10:56
Thanks. I was paranoid that they fit into the head gasket and would have to pull the head again. Good news.
