Dumb Question: JD A Oil Dipstick
Lane R
11-26-2005 14:00:46
Can anyone tell me just where the oil dipstick is on a model A? I guess this old dipstick is just having trouble finding the tractor"s dipstick.
Thanks for the help
buckeye al
11-29-2005 05:41:19
 Re: Dumb Question: JD A Oil Dipstick in reply to Lane R, 11-26-2005 14:00:46
Be nice guys.....
While they are not particularly common, there were aftermarket "fittings" that would set your JD tractor up with an oil level check dipstick!
You removed the original JD oil test level plug assembly & this unit screwed right in to the same hole. The unit then had a slightly elevated DIPSTICK about 4" long that screwed in at an angle. It had a knurled knob atout 5/8" in diameter for you to screw it in & out with. No tools required to check oil, no drips on the floor unless the level was too high. There is one on my 44 hand start A. No idea who made it & have only ever seen two of 'em but the point this dipstick is trying to make is that an A (or most any other old JD) COULD indeed be equipped with an oil level test dipstick though they were not particularly handy on the H!
MUD MASHER
11-28-2005 23:01:55
BELIEVE IT OR NOT , MY "52 GN HAS A DIP STICK!
I BOUGHT IT "99 FROM THE ORGINAL OWNER THAT STILL FARMED MILO AND COTTON W/ IT.MAN, DID HE HAVE THE CONTRAPTIONS BUILT ON THAT THING.CUSTOM FOOT REST,EXTENDED STEERING WHEEL,BILATERAL RODS TO OPEN PETCOCKS FROM THE SEATAND LAST BUT NOT LEAST A....DIP STICK. IT WAS MADE OUT OF NIPPLES AND 90"S A LONG NIPPLE AND A CAP THAT WAS DRILLED AND WELDING ROD PLACED(TACKED) AND FILL MARKS ON THE STICK.THEY ALL WORK GREAT!
WHEN THE G IS RESTORED IT WILL HAVE ALL THESE OPTIONS PLACED BACK ON IT.
ENJOY,
MM
steveii
11-27-2005 10:41:18
you will find the dip stick out of one end of your ear as it goes out the other ear.
Island A
11-27-2005 05:40:34
You're no dipstick, there is no dipstick!
My '49 A has a plug on the right side under the belt pulley. Loosen it a few turns and pour oil into the crankcase until it drains from this plug.
Dave
70 DS
11-26-2005 19:55:11
Our 51 A Has a plug that you loosen under the clutch pulley and oil drips out when it is full.
JD @ Antique Acres
11-26-2005 16:54:58
Depends on what year it is later A's the check is below the pully.
in-too-deep
11-26-2005 14:37:03
And your oil-fill is that large cap on the belt-pulley-housing-area. It's 2-inch in size I believe.
amoo
11-26-2005 14:14:40
their is a bolt sticking out from crankcase under the flywheel. loosen this and oil will run out when it is full or to proper level
CLW
11-26-2005 18:15:44
 Re: Dumb Question: JD A Oil Dipstick in reply to amoo, 11-26-2005 14:14:40
Wouldn't that be for very early A's. Ones I drove were below and just fwd of clutch pully. At about 5 o-clock.
CLW
