4020 steering slop
Ray Hudson
11-26-2005 04:05:54
4020 spindel / arm spline has a lot of wear farm ind news talked about a product that would take this out something like j b weld what was it and has anybody tried it
jdemaris
11-26-2005 10:16:01
 Re: 4020 steering slop in reply to Ray Hudson, 11-26-2005 04:05:54
The JB Weld repair won't last 1/2 an hour. Deere Company sells a worn spline and shaft repair kit that is a much tougher epoxy and metal compound an it works pretty good for high stress areas. We used it on the axles and hubs on 440 and 540 skidders, 2010 wheel tractors, etc. I used in on a worn bushing on my backhoe. Same spot where I'd tried J.B. Weld that had failed almost instantly. I put the Deere stuff on and it held up all summer. I'm sure you can buy the Deere stuff eslewhere and cheaper. It was made by Devcon.
G/MAN
11-26-2005 10:07:31
I'd look into a new aftermarket spindle and arm. Anything else is a band-aid, and unlike a lot of "competetive" tractors, the Deere spindle/arm setup will hold up great if everything is as it should be. The tapered splines are way better than the clamp-on junk and the like some of the others use(d). As long as you don't have a loader on it and aren't beating the heck out of it, good aftermarket parts should last fine. If you WERE going to use it hard, I'd strongly recommend paying the extra $$$ for OEM pieces. There is a difference.
4010guy
11-26-2005 08:47:17
befor u buy a spindel grind a little off the top so arm fits tight
Boo Lyles
12-09-2005 16:22:30
 Re: 4020 steering slop in reply to 4010guy, 11-26-2005 08:47:17
I'm with the 4010 dude...I'd definatly grind off the top where the arm goes on...It'll let it pull tight back into the spines...By the way..I've got a Johndeere silage cutter 1 row..1967 model. My daddy bought it new in 67..I'd just like to know if anybody can relate to that I'm gonna restore it ..but I'm having trouble finding certain chains ..That's all ...I'm out !!!
zr
11-26-2005 08:24:27
I bought a new, aftermarket spindle for a 4020 for much, much less than JD wanted.
donmyeil
11-26-2005 06:58:13
You might get by with replacing the cast arm if the splines are not worn too much. otherwise I would bite the bullet and replace the spindle.
TwoCylinderDiesel
11-01-2006 14:49:53
 Re: 4020 steering slop in reply to donmyeil, 11-26-2005 06:58:13
I need to replace the spindle on my 4020, the part number looks like it is R53275. Is that a valid part number?
