JD 520 Power Steering on a 50
copter
11-25-2005 21:33:47
I want to put power steering on my 50. Will parts from a 520 fit on it? Any idea what a salvage place might want for em?
Mike Aylward
11-26-2005 16:46:55
 Re: JD 520 Power Steering on a 50 in reply to copter, 11-25-2005 21:33:47
Copter, depending on the serial number, you also might need the upper radiator tank. The later tractors had the tank notched to allow room for the steering valve, regardless of whether the tractor was ordered with Power Steering. I don't have the list in front of me now but you cannot install the parts if this tank is the wrong one. There simply is not room. Buickanddeere is right- check the parts books for similarities before you do anything. Mike
donmyeil
11-26-2005 07:01:04
It will work but you have to change everything , pedistol to the steering shaft. look for $1500 and up.
jd jerry
11-26-2005 06:19:54
This could be a good thread. My son has a A that needs a front ped. and he was thinking of tring to put a 620 front on. I guess if we had both tractors side by side we could make visual checks. Pull the grills and see how the A stuff fits on the 620 and bolt patterns and stuff. Mayby on a nice day I could go get my 620 (it is over at my Dads). He would want it to look like the A.
buickanddeere
11-26-2005 06:44:51
 Re: JD 520 Power Steering on a 50 in reply to jd jerry, 11-26-2005 06:19:54
How about fixing up the 620 and forget about the A. The 620's live hydraulics, live pto, proper three point hitch and optional power steering.Plus the increased power, smoothness and fuel economy makes an "A" look pretty grim.
jd jerry
11-26-2005 14:17:12
 Re: JD 520 Power Steering on a 50 in reply to buickanddeere, 11-26-2005 06:44:51
The 620 doesn't need any fixing up. The A had the front ped cracked when my uncle was loading a truck with gravel 40 years ago. He wants to get rid of the weld. The A has the mag pump, wide front, power block, 801 three point and fits in with my B and G. If the 620 front will work on the A I will look for a 720 front for the G.
buickanddeere
11-25-2005 22:30:10
Get the parts manuals for a 50 and 520/530 and see what is common. 1-800-522-7448.
