G with LP conversion
RLS in PA
11-25-2005 17:11:34
I found a G that was converted to run on LP. Would that work with the stock 4.2 to 1 compression ratio or did cylinder inserts come with these kits? Are these converted G's a common find?
CMB
11-26-2005 10:35:54
 Re: G with LP conversion in reply to RLS in PA, 11-25-2005 17:11:34
This has been an awfully long time ago, but seems like back in the 1960"s, the old "Tractor Supply Co" sold aluminum "high compression" kits for most 2cyl Deere"s & maybe some other brands. If I remember correctly, (only because I was farming with a "G" at the time) they advertised the pistons for a "G" at 7-1 compression ratio for gasoline,& 8-1 CR for use with LP conversions. When I redid my "G" with another brand of aluminum pistons, it dynoed at about 52HP on Gasoline.
Duane Larson
11-26-2005 16:31:41
 Re: G with LP conversion in reply to CMB, 11-26-2005 10:35:54
CMB,
Your memory is pretty good - the 1961 TSC catalog offers aluminum pistons for most Deere's - increasing the compression ratio to about 7:1 for gasoline and 8:1 for LP pistons - available up to 125 oversize.
FWIW, power blocks also offered pistons for LP operation, with the compression raised from 6.4:1 for gasoline to 7.7:1 for LP.
G/MAN
11-27-2005 11:37:29
 Re: G with LP conversion in reply to Duane Larson, 11-26-2005 16:31:41
Yep, I've got a scanned copy of an old Power-Block ad, and it shows both gasoline and LP kits.
430WLPG
11-26-2005 08:04:46
They have a M&W style Hi comp. pistons mostly, but there was several different versions from several manufacturers,such as J&S ,H&S,Johnson,I have have one on a 52 and a 52 we converted back to gas,and have had at least 5 others,One of which I sold to a guy in Pittsburg
buickanddeere
11-26-2005 06:48:35
If it's a clean professional conversion instead of something done by some farmer in a hurry who used only vice grips, a hammer and a cold chisel. Then keep her as is and display at shows. The single barrel carb/intake will distribute vapour fuel better than mist/liquid/droplet fuels.
960
11-26-2005 05:57:20
I am in central IL and hauled one back from north Texas just because I wanted something different for the shows and I enjoy tormenting the correct police. I runs but needs an overhaul. This winter I will take it apart and I too am curious what pistons may be in it.
MSD
11-25-2005 20:48:00
I had one for a while. Was rougher than heck looking but was the sweetest running G I ever heard. I converted it back to gas and it still ran nice. I never went inside to see what was done to it though.
Glen in TX
11-25-2005 19:41:39
I've seen several Gs converted to LP but never seen or heard what was inside them. Probably higher compression pistons you would think.
