Fuel injectors on a Duramax
JAwa
11-25-2005 12:03:18
I know this is a John Deere Forum but I know a lot of you have Duramax experience.
How often should the fuel injectors be cleaned?
Also do you recommend a fuel additive?
G/MAN
11-25-2005 13:17:50
 Re: Fuel injectors on a Duramax in reply to JAwa, 11-25-2005 12:03:18
Stanadyne makes an excellent diesel fuel system additive, and I believe other manufacturers (including JD I believe) sell it under their names. Supposed to reduce fuel system wear and resist damage from water in fuel.
Ray
11-25-2005 13:13:02
I've got an 01 duramax, I use fuel treatment because the early ones had some injector problems,I never had though.I got letter from
GM saying they were extending the injector
warranty to 200000 miles so I'm not worried.
Ray
11-25-2005 13:16:32
 Re: Fuel injectors on a Duramax in reply to Ray, 11-25-2005 13:13:02
There's really nothing to clean,just make sure you change the fuel filter pretty often.The newer ones have an extra filter,dirt will ruin
the injectors.
mark ace
11-25-2005 18:22:52
 Re: Fuel injectors on a Duramax in reply to Ray , 11-25-2005 13:16:32
a real simple cleaner for diesel fuel systems is add a quart of automatic trans fluid when you fill up
