How do you take rockers apart in a model D
Dave Siekkinen
11-25-2005 09:19:55
How do you get the shaft that the rockers ride on out of the valve cover? Do you just press from one end and out the other? How do the end caps seal? Thanks
Dave Siekkinen
11-25-2005 13:36:56
 Re: How do you take rockers apart in a model D in reply to Dave Siekkinen, 11-25-2005 09:19:55
Thanks guys! I just got it apart using your advice. I figured I"d get some wisdom before I took the B.F.H. to it. Where is a good source for those plugs? Thanks again, Dave
Glen in TX
11-25-2005 15:01:56
 Re: How do you take rockers apart in a model D in reply to Dave Siekkinen, 11-25-2005 13:36:56
JD dealer should be able to get them part # 30H 13R welch type plug. Older auto supplies might have some yet also. I can also sell you some if you can't find them local and have lots of sizes of welch plugs I bought from older local auto supply that was going to throw them in scrap pile. Many other older engines used the "welch" concave/convex plug.
JGC
11-25-2005 13:06:23
It's been about 3 years since I re-built my late model 'unstyled' "D" but as I recall, there is a cap screw & lock nut inside the tappet case. The point of the cap screw goes into a hole in the shaft so make sure you back the cap screw right out! Carefully tap on one welsh plug which drives the shaft and welsh plug out the opposite end. The welsh plugs are made of soft metal and are domed. They expand when you carefully tap on the centre of them. I bought new plugs and sealed them to prevent future oil leaks.
Someone else who has done this procedure can confirm what my aging brain recalls! LOL
NOTE: There are several plugs, bolts, cap screws etc that go into the crankcase or transmission case from the outside. I suggest sealing all of them to prevent future oil leaks. These "D"s tend to leak!
Glen in TX
11-25-2005 12:56:11
Dave, After you get the rocker cover off inside you will see a set screw and lock nut holding the shaft. Loosen those and then punch out one or both of the welch plugs on sides and it will just slide out then. Should be a drilled hole in the shaft that the set screw fits into during assembly and then put some permatex or gasket sealer under the new welch plugs and punch them in center to expand them into holes.
