CARBURATOR PROBLEM?
Dave Schmidt
11-24-2005 08:26:47
I purchased a used 1997 Model 345 John Deere (344 hrs). I have a starting problem that I think is Carb related. On a cold start the engine will only start if the throttle is in the lowest (idle) position. It seems that it is always flooded on a cold start. If I leave the throttle in the low position and continue to crank the engine it will eventually start. After it warms up and I use the tractor during the day there is no starting problem. Perhaps a carb overhaul kit will do the job.
Comments are appreciated.
jd b puller
11-25-2005 08:38:55
 Re: CARBURATOR PROBLEM? in reply to Dave Schmidt, 11-24-2005 08:26:47
Dave, check your valve settings. Also check your cylinder compression once the engine heats up. If you can run a cylinder leakdown test, it also might show that you have a leaking intake or exhaust valve.
Jim Dunn
11-24-2005 12:38:57
I have a 520 JD that my father-in-law bought new in 1958. About 10 years ago, it got so it would only start with the throttle pulled all the way to the idle position and the colder the weather, the longer I had to crank on the starter. I just restored the tractor last year and found that there was a crack in the head. I firmly believe that when the tractor sat, some moisture migrated into that cylinder and some heat had to be generated to dry it up enough for it to be able to fire. I spent several dollars trying to make sure I didn't have weak fire or something along those lines and never located the problem until I pulled the head and found the crack. The engine has been back together over a year now and I haven't seen any starting problems as yet. She can sit for 2 or 3 weeks and the instant you hit the starter, she is up and running. Hope this isn't your problem, but if you go into her, look good at the head.
Hoosier JD
11-24-2005 20:30:55
 Re: CARBURATOR PROBLEM? in reply to Jim Dunn, 11-24-2005 12:38:57
I had that same problem with a little STX 38 until I realized that I should shut the gas off after every use. I just made it a habit to lift the hood and turn the inline valve off. When I went to start it, I just checked the oil and turned the gas on. Don"t know if this is your problem, but sure cured mine. Good luck, Mike.
