44 BW Oil Pressure
CalJim
11-23-2005 22:15:36
Hello all,
Just finished a total rebuild on my 44 BW.
My question is this...should I be able to
get an oil pressure reading by turning over
with starter? At this point my carb and mag
are still at the rebuilder. I have cranked
over for 5 seconds or so and saw nothing.
I have new gauge and have rebuilt the oil
pump. Thanks Jim
Paul_IN
11-24-2005 07:15:55
 Re: 44 BW Oil Pressure in reply to CalJim, 11-23-2005 22:15:36
Cranking it over before starting it is an excellant idea. It will probably take 20 seconds or more to fill the oil filter cavity and then register pressure. One question - you did prime the oil pump before putting it back in place? It might not be totally necessary on the 2 cylinder tractor with the pump pretty well submerged, but good practice non the less that we've always followed. Good luck finishing up your restoration. I'd like to have a early styled BW myself.
40 JD G
11-24-2005 06:24:28
It will probly take longer than that it has to fill the filter and all the lines, but it will work by cranking it with the starter. I just got done restoring an unstyled G and i did not want to start it until i knew i had oil pressure, i had to hand crank a that thing with a new bore, talk about work.
Nick
wddave
11-24-2005 08:41:40
 Re: 44 BW Oil Pressure in reply to 40 JD G, 11-24-2005 06:24:28
Disconnect the line for the oil gage and crank it over until the oil comes out then you should be ready to go.
