B fan shaft gears
Doug L.
11-23-2005 17:54:25
I posted a meesage yesterday about my fan shaft gear not meshing with the drive gear inside the govenor housing. Upon further look I could see that the drive gear was not being pusded forward far enough and the cause appears to be a complete lack of those shims in the rear (left side) bearing cap. The mag end is spring loaded and I assume the shims apply enough force to compress that spring to the right clearance between the two gears. Is that true? I think if the whole shaft had shims to move it to the left further the gears would mesh fine. Maybe someone pulled it apart and lost the shims sometime ago. How many shims are there supposed to be and are they of various thicknesses? Thanks to all again Doug L.
Doug L.
11-24-2005 12:54:56
 Re: B fan shaft gears in reply to Doug L., 11-23-2005 17:54:25
Thanks very much to all who helped on this. I believe I have it now. The advice has been expert. Someone mentioned that the bearing may be in the sump. I completely rebulit that end so know it is not in there. I know the guy I got the tractor from and he is kind of known in our circle as having too many things going at once. I believe he took the cover off put the bearing somewhere and that was that. You are right that the two bearing races are still there. It's just the bearing missing and I understand how the shiums work now too. I'll be talking to the parts man on Monday. Will be a good story to tell someday, but I sure like working on something that isn't a jig saw puzzle. Thanks again and have a Happy Thanksgiving. I smell turkey as we speak.
Mike M
11-24-2005 05:09:57
Jasons picture is how it should look in there. His gear teeth have a lot of flat area, not worn down to sharp points. This picture also shows the best way to set them up. Take everything off and clamp it in a vise pointing straight up it's really the only way to see what's going on in there.
Doug L.
11-23-2005 22:55:24
Jason, I just came in from the shop after looking this over again and I think it may be even more confused. The most serious problem I just recognized is that the rear (left side) bearing is completely missing from the govenor shaft. Someone obviously dismantled the govenor and removed the bearing or forgot to replace it. Now the shims you are speaking of have me confused. I would think that by adding shims to the back (left side) that that would put more pressure on what the book calls the preload spring on the end where the mag mounts, thus pushing the two gears closer together. If you removed shims it would put less preasure on the spring thus increasing the gear gap. Maybe I am not understanding where the shims go. I think mine were so far apart due to the missing bearing ans shims. Tell me this, when you put the back (left side) plate (bearing cap) on your govenor and started to tighten down the four bolts that hold it on, is that what pushes the gear into position where it mates with the fan shaft gear? That is, in order for my gears to be in the right place, I need to push hard on the left side to start colapsing that preload spring on the mag end and it looks like if mine had all the parts when a guy would pull that left side plate off, it would pop off under a pretty fair preasure. Do I have this right or am I looking at this all wrong? Sure wish I could see one that wasn't missing parts to figure this out easier. I can get pictures of mine tomorrow. I'll have to figure how to load the picture on here or maybe I can email to you directly. At any rate it is late here in Oregon and I have had enough for one night. Thank you for all the assistance and Happy Thanksgiving tomorrow.
Jason Z in MO
11-24-2005 07:15:23
 Re: B fan shaft gears in reply to Doug L., 11-23-2005 22:55:24
Doug,
I think Lee has it covered! That bearing you are missing is a 3 piece bearing. The outer cup is pressed into the cover, the inner cup (cone) is pressed onto the end of the governor shaft and the bearing itself is between the two and it a ball bearing; not roller or taper roller. As Lee points out pack that bearing with a little grease it will help pre-lube it and hold it into place. Be sure to place the bearing into the outer cup when assembling. If you hang it on the inner cup it won't seat correctly with the outer cup.
As Lee stated, the shims install between the cover and case. The more shims stacked up the farther away the cover will be from the case, the less the spring will be compressed, the less your gears will be in mesh.
If you have problems getting the spring compressed to get the bolts started, use a screw driver or bar between the case and cam gear.
Bearings and shims are all available from JD. The original were ND or New Departure. I have the numbers in the shop if you need them.
To post a picture you have to either download it to the "Parts & Pieces" to the left of the window. Once downloaded cut and paste the URL for the picture into the "Optional Image URL" field in the "Post a Followup" box. Another place to download pictures is at "www.tinypic.com". It's self explanatorily.
Jason Z in MO
11-24-2005 08:25:56
 Re: B fan shaft gears in reply to Jason Z in MO, 11-24-2005 07:15:23
Doug,
Just thought of another point you need to check. Remove the governor assembly and check the barrel or hole (magneto side) which the pre-load spring and right hand bearing enter. There is a possibility the bearing wore a groove in the barrel which will prevent you from keeping the fan gears in place.
Good luck and Happy Thanksgiving all!
Jason
Lee B
11-23-2005 23:44:51
From what you describe all that you are missing is the bearing itself, somebody forgot to use a gob of grease to 'stick' the bearing to the race on the left cover during the last assembly and it's now in the oil sump? Hope it wasn't run very long like that...
Pushing hard on the left cover to preload the spring is a bit of a stretch. Hard isn't the right word to use, but neither is easy because it sure ain't easy to get those first two cover bolts started. You can get a bit of a sweat worked up alright.
Watch out for 'not available' bearing numbers as they are available but under a different numbering system. IIRC you need to drop a -1 or an '-a' from the number and the bearing and/or race will then show as available if you don't find it in the sump. My 44 A uses a BCA B-01 for all three governor bearings, Checker had them for $35, Mother Deere $55.
Advice is correct IF one had a bearing in there, you remove shims to tighten gear clearance and put them in there to have more gear clearance. The shims are no more than stacked gaskets for the left cover, they do NOT go under the bearing race itself, perhaps that's the issue causing your confusion?
Jason Z in MO
11-23-2005 21:21:38
third party image
Doug,
Greenmech is right more shims will widen the gap. The "thin" shim is .005", medium = .015", thick = .025" At least thats what mine measured a few days ago when I was putting it together.
Do you have any pictures?
greenmech
11-23-2005 20:33:57
A look at the parts book indicate that you would remove shims to make the gears mate tighter. More shims would move the gears apart Don"t know the thickness of the shims, but they are listed as thin ,medium ,or thick. Could be your bearing is worn out on the flywheel side.Ron Mn.
