Steering arms sloppy
Arthur Driesse
11-23-2005 17:45:07
I have a problem with one of the steering arms being loose on my 60 and on my 3020. In between the steering arm and the spindle there is some play. Is there a way to fix it without replacing parts, the washers on top of the spindle are already removed. Thought about machining a hair off of the bottom of the arm on the 3020 but I cant do that on the 60. Could I shim it in between the splines? If so how? Not sure what to do...
Jonathan in MA
11-23-2005 18:00:39
 Re: Steering arms sloppy in reply to Arthur Driesse, 11-23-2005 17:45:07
There is a kit available from Deere thats used on the industrial machines.. Older backhoes.. 310's 410's etc to repair the steering knuckle to spindle joint. It is a "liquid steel" type epoxy thats mixed and put into a caulking gun tube. It is then injected into a hole in the steering arm into and onto the splines. It works pretty good and is cheaper than new parts. There has to be "some" spline left though...might be worth a try
