50 series
Randy Losey
11-23-2005 15:47:18
I am looking at a 50 model tractor and wondering if they have any value? This tractor has been sitting for sometime and looks to be missing the grill and rad. has a single front wheel. Please let me know what is a fair price for both the seller and buyer? Thank you.
buickanddeere
11-25-2005 15:07:16
 Re: 50 series in reply to Randy Losey, 11-23-2005 15:47:18
Run the serial number with Two Cylinder Club just to make certain it doesn't have some exotic history. I almost parted out an 840 which was a engineering research mule. Purchase this one for spare parts and get a running 50.
John Van Valkenburgh
11-23-2005 23:19:18
Randy,
The 50 series isn't especially rare. They were made from 1952-1956 and replaced the model "B". After the 50 came the 520 and then finally the 530 which ran until 1960 when John Deere stopped making the traditional 2 cylinder tractors.
From a usage standpoint the 50 is more desirable than the "B". It has a bit more power. They often came with live Hydraulics and Live PTO. The 50 used a duplex carb which gave better performance. Lots of model 50s still out there and in use (mine included). The other tractors of the same vintage include the model 40 which took over for the "M", the model 60 which took over for the "A" and the model 70, which was a hoss.
Many of the parts for the 50 are still available from John Deere. Lots of aftermarket parts for that model as well.
From a collectors standpoint its a nice machine, but not rare. I've seen prices for 50s in good running condition range from a little over a $1000 to well in the $3000 range. It depends on what's been done to it.
The single front wheel is not as commonly seen as the dual front row-crop wheels. Most 50s had the roll-o-matic front end.
Now in your case the missing radiator suggests to me that this particular 50 has been at least somewhat stripped and probably has not been recently rebuilt. Meaning that once you replace the missing radiator the engine may still need attention. This of course significantly reduces its current value. Personally I would say its more like a $500 tractor in this condition. Hard to tell what shape the tractor is in without it running.
Look over the photo ads on this site. 50s are available. The question is, are the available near to you?
Best of luck and let us know if you get it,
John
1953 Model 50
JDVan
11-23-2005 21:31:20
There are several factors that could significantly impact it's value. Year, serial number, size of single front tire and rear tires. "All Fuel" vs Gas only vs LP, etc, Casting number on cast rear centers, casting number on rear axle housing, does it have a 3 point hitch on it - 800 or aftermarket, Power steering, Tachometer hours, is it stuck, any noticeable cracks. Intake or exhaust manifold cracked, The list goes on. Sometimes free tractors are too expensive.
Randy Losey
11-23-2005 19:44:31
Are these much of a collector or isthereanything special about the 50 series?
DickD
11-23-2005 19:41:07
Randy; I never am willing to pay over $600 or $700 for a tractor that wont run. The single front wheel makes it a little more valuable, and of course tires, metal and the deciding factor is how mad your wife is gonna be when you drag it into the driveway.
