80 power steering unit removal
superfarmer
11-23-2005 12:54:25
Well, I've determined that the o-rings on the power steering vanes are leaking, but I can't get the whole unit to lift off. The steering gear arm on the bottom that attaches to the tie rods won't come off. I've tried jacking up on the shaft and hammering, but no movement. Any ideas how to get it off? I need it off to pull the whole unit with the shaft out of the tractor to get the bottom bolts out. Thanks.
Dave
robertq
11-23-2005 13:31:16
 Re: 80 power steering unit removal in reply to superfarmer, 11-23-2005 12:54:25
I think a bit of up pressure on jack, and a sharp blow to side of arm at the spline area hopefully snaps it loose.I had a leaky 830 and I think one o ring in bottom area fixed the leak,thought it was going to be a long drawn out affair but was not bad at all.
Duane(Pa)
11-23-2005 13:14:55
I'm sure you have the bolts out that hold the unit to the main case.(it has to have somewhere to go) I think you can get a two jaw puller on the little flange, but the jack should give just as much power. Might have to use heat? It's a tapered spline and they can be tight.
superfarmer
11-23-2005 18:41:14
 Re: 80 power steering unit removal in reply to Duane(Pa), 11-23-2005 13:14:55
Yeah, that's just about what i figured. Not crazy about the heat with all the oil leaked and spilled over the ole girl. She'd really heat the shop up quick! Wanted to make sure there wasn't something else to do before going to those measures. Thanks...
