B fan drive
Doug L
11-22-2005 23:46:37
I have a 1948 B that I was reassembling after a rebuild and now find that the bevel gear that drives the fan shaft does not mesh with the gear in the govenor. I have never seen the tractor run so think this may be something that existed before I bought the tractor. I did not find any metal shavings or anything like that in the givenor housing when I tore it down but the gears are pretty far off from meshing. Is there any trick to meshing these gears again. I don't see how there could be. Seems that maybe the bevel gear on the fan shaft is just plain wore out. Would anybody have one? Thanks Doug L.
Jason Z in MO
11-23-2005 07:02:16
 Re: B fan drive in reply to Doug L, 11-22-2005 23:46:37
Doug,
I can post that picture again if you can"t find it. Like Mike M said, the meshing of the gears is controlled by the shims under the left hand governor bearing housing/cover. Remove shims to bring the two gears closer. The backlash or play between the gears should be .004-.007". That previous post Mike mentioned talks all about this.
You said the gears might be worn out. I"m not an expert but I have seen these gears which the teeth have worn to sharp edges on the tips. The tops of the teeth should be flat. A lot of material has worn away for the tips to be sharp.
Mike M
11-23-2005 05:41:36
Go down a few posts and someone asked about a B governor and posted a very good picture of what good gears should look like. If they are way out of mesh something may not be assembled right. It's very common to find stuff not put in correctly by previous repairers. Do you have a copy of the parts book ? These are very good at helping get things in the right order. The gaskets are shims to adjust alignment but you don't have that much adjustment to get them way out.
Doug L.
11-23-2005 06:37:01
 Re: B fan drive in reply to Mike M, 11-23-2005 05:41:36
Thank you Mike. I may have a chance to see another one today to compare. I know what you mean when you follow in someone elses shoes on a restoration. I only pulled the fan shaft out of the govenor housing and never really checked to see if it was meshing then but I just don't see how it could have. Thanks and I'll do a comparison on gears.
