420 clutch shaft lube
peteellis
11-22-2005 17:24:40
have 420c and after it sits the clutch shaft binds up. any cure except disassembly??
CPeter
11-22-2005 18:52:29
 Re: 420 clutch shaft lube in reply to peteellis, 11-22-2005 17:24:40
Do you mean that the clutch and brake pedals lock together? If that is the problem, you may be able to remove the left hand crank from the brake shaft and slide the shaft out the right side and then work the PB Blaster to it to clean out as much of the rust as possible and then put a good waterproof grease to the shaft and the hole in the left side of the clutch shaft and work the grease into it and then reassemble the whole thing. I have good had good luck with the PB Blaster working it into the area around the right and left sides of the housing and keep at it and finally getting it free.
CPeter
