5020 hyd. oil drain/change
jd jim a
11-22-2005 17:18:48
Trying to drain and change the hyd. oil on a 5020. Found two drain plugs on the bottom of the transmission case, removed the suction screen, and the filter. Only got about 10 gallons out so far. It was close to the full mark on the stick when I started. Am I missing a plug or something, or is that all the oil it holds? Is a bunch of oil trapped in the system somwhere? I want to do as complete of a drain and change as possible.
Glen in TX
11-23-2005 09:34:44
 Re: 5020 hyd. oil drain/change in reply to jd jim a, 11-22-2005 17:18:48
jd jim, I think it would hold 16 gal. of trans/hyd oil like the 5010 and 6030 did. Never owned a 5020 but would guess it to be the same. Being a ways below full mark on those tractors is several gallons. Usually takes 2 gallons or more at least to bring it up from the safe mark. All 3 had the same transmission I believe? You might want a operators manual if you don't have one. Can get them from JD yet or find them on classifieds here or on ebay sometimes.
