JD 5420 fuel line bleeding...
spray004
11-22-2005 15:43:23
I changed the fuel filter on dad"s 5420 today. I cranked the tractor and it ran for a few seconds then shut off. I"m assuming there is air in the fuel lines and it needs to be bled. I pulled the line going from the filter into the injector pump and there is fuel going in, however there is no fuel leaving the injector pump. Can someone point me in the right direction for the procedure for bleeding the lines? I"m pretty new to diesel engine maintenance/repair.
Thanks
Gerry_Luzerne_MI
11-23-2005 05:32:12
 Re: JD 5420 fuel line bleeding... in reply to spray004, 11-22-2005 15:43:23
I had a 5420 ( 2003 ) and changed the fuel filter at 100 hours for the first time per the manual. It was a bugger to get going again. I cranked it for a long time until it took. I don"t think you have damaged the pump seeing that it was wet. If it were a new pump and dry, that is a different story. Can"t remember if there is a bleed screw right above the filter. If so open it to get the air out. I have also left the bowl lose to let the air out. It will start, when it is ready. Gerry
720 Lyle
11-22-2005 19:58:40
They are a bugger to prime. Be sure to follow the manual which says the tank should be full.
burnetma
12-04-2005 18:00:22
 Re: JD 5420 fuel line bleeding... in reply to 720 Lyle, 11-22-2005 19:58:40
You are not kidding that they are a bugger to prime. I just love the fact that you have to be on both sides of the tractor at the same time to do the job correctly and generally it takes two times to get it right. Honestly, it is enough to make me wish I considered a different tractor! Not sure why JD could not put a self-priming system like my Powerstroke. I paid more for the Deere.
Any after-market systems???
spray004
11-22-2005 16:10:01
Hey guys I found dad's owners manual and the procedure for bleeding the fuel system. My only question now is that I tried starting the tractor 5-6 times after air had got into the lines. Do you think I might have damaged the injector pump or does it take a lot to damage it?
spray004
11-23-2005 14:18:00
 Re: JD 5420 fuel line bleeding... in reply to spray004, 11-22-2005 16:10:01
We got it running this afternoon, thanks guys.
