2010 backhoe starting problem
Jeremiah
11-22-2005 12:54:22
Hello, I'm here pulling my hair out about my backhoe and could use some advise.Two weeks ago I ran my hoe to dig a cistern, the engine fired propely.
The next day I went to fill in the hole, It started up fine. I was backing up the hill and went to move the hoe to the center position while in motion . The tractor died.It was about 30 degrees out. Now what happens is that the engine will crank real slow.
I put jumper cables on it , no effect. I pulled the starter off and it looks to be good. It operates on the stand as it should. A guy I work with said that it might be the pump in the transmission being locked up?? Any info would be appreciated. Thanks
Timberoak 2119
11-22-2005 17:53:22
 Re: 2010 backhoe starting problem in reply to Jeremiah, 11-22-2005 12:54:22
The above mentioned comment on the destroke valve is on the closed center hydraulic system on the 3010 and 4010, the 2010 is open center with a gear pump, sounds to me like a hydraulic hose coupler became disconnected and you are trying to start against relief valve pressure or one of the operating valves for backhoe or loader has not returned to neutral, it is trying to move a cylinder that has reached the end of its travel and is working against relief valve pressure. Check these out. David
Jeremiah
11-23-2005 15:52:49
 Re: 2010 backhoe starting problem in reply to Timberoak 2119, 11-22-2005 17:53:22
I thought that that the Hyd. pressure might be a problem ,so I disengaged the hydrolic pump up front. Nothing changed. Jeremiah
richlizzy
11-22-2005 16:46:13
There should be a pump bypass destroke valve on the top of the hydraulic pump on the front of the engine. Screw it in to destroke pump and take load off of starter. Engine should fire right up. Once started, screw valve all the way back out or it will leak. Mine only takes about 1 to 1 1/2 turns. Mother Deere will gladly sell you a electric destroke kit, but it is pricey.
