1020 Gas (new project)
Vinnie
11-22-2005 05:40:16
I just bought a non-running 1020 gas at auction. Since I have not picked up manuals yet, can someone help me with the points gap?
Also, I would like to install a fuel filter, but the lines are "hard plumbed" from tank to fuel pump and from fuel pump to carb. Any suggestions? Could I use a glass bowl type and insert it into one of the lines?
Thanks for any help or suggestions.
-Vinnie
Tom in Mo.
11-23-2005 03:47:44
 Re: 1020 Gas (new project) in reply to Vinnie, 11-22-2005 05:40:16
I recently bought a 1020 and looking at the fuel pump it looks like there is a filter/strainer inverted on top of the pump. I don't have a parts book either yet so can't verify.
Ten-Twenty
11-23-2005 08:55:52
 Re: 1020 Gas (new project) in reply to Tom in Mo., 11-23-2005 03:47:44
Tom,
From the 1020 Service Manual (SM-2071), "A strainer, attached to the fuel inlet elbow, cleans the fuel, before it enters the bowl". They are referring here to the fuel inlet elbow to the carburetor. There is, however, an additional screen in the fuel transfer pump.
Vinnie
11-24-2005 15:35:13
 Re: 1020 Gas (new project) in reply to Ten-Twenty, 11-23-2005 08:55:52
Thanks Tom and Ten-Twenty. I removed the carb today and cleaned it out then re-assembled it. Apparently my carb elbow filter is long gone! I have not removed the connection at the pump yet to see if there is a screen in that connection.
I wanted to cut the line and install a glass sediment bowl just before the carb, but its a little tight for space. The line on my tractor is 5/16, which makes it hard to find those type of fittings. I was able to find (brake line) steel line and fittings at Advance Auto (in the back, not on the shelves).
Now that I have the carb clean, I have decided to cut the line just before the carb and install a clear plastic filter with two short pieces of fuel line clamped to the metal line. I hate to hack it, but I don't think it will look too bad.
-Vinnie in NC
Ten-Twenty
11-22-2005 06:28:21
Vinnie,
Congratulations on your purchase!
The distributor breaker point gap is 0.020-inch. The spark plug gap is 0.025-inch.
