JD 4640 Power Steering
shawn alfonsi
11-21-2005 21:29:36
Where do you put in the Power Steering Fluid? What's the fluid capacity? I had a hose leak and I'm a little nervous about pouring fluid directly into the hose, but where the heck did they put it? I put in 2.5 gallons, and I'm not sure if I'm even close. Any help would be GREATLY appreciated.
Thanks in advance.
Shawn...
Bob
11-21-2005 22:28:36
 Re: JD 4640 Power Steering in reply to shawn alfonsi, 11-21-2005 21:29:36
There is only one reservoir for ALL the hydraulics on the tractor... the transmission and final drive case.
Oil is check with a dipstick at the back of the tractor, and the filler cap is not too far from the dipstick.
shawn alfonsi
11-22-2005 08:07:25
 Re: JD 4640 Power Steering in reply to Bob, 11-21-2005 22:28:36
Thanks so much...Then what's that odd shaped tank up in front of the radiator that the power steering hoses go into? It has a weird shaped tank and a long 18" steel pipe coming out the top, then all the hose attach to it.
You're the best...Thanks so much for the help.
Have a great Thanksgiving...
Bob
11-22-2005 08:40:10
 Re: JD 4640 Power Steering in reply to shawn alfonsi, 11-22-2005 08:07:25
That is a reserve tank for the front hydraulic pump. It is continuously kept filled by oil coming forwards from the transmission pump, and function returns. The oil is cooled by the cooler, keeps that tank full, then the excess beyond what the front pump needs to keep up with hydraulic demands flows rearward, and provides lube for the transmission bearings and gears.
shawn alfonsi
11-22-2005 10:25:34
 Re: JD 4640 Power Steering in reply to Bob, 11-22-2005 08:40:10
You're awesome! Thanks so much for the help. YOU really did help.
Again, THANK YOU!
Shawn...
