jdemaris
11-21-2005 18:40:18
Re: JD 3010 Diesel hard to start. Normal? in reply to bonerack, 11-21-2005 18:26:13
Some were dogs from the day they were new, and some would start at 10 degrees F with no ether and no block heater. Since you've got a used tractor, and you don't seem to know its history, you can't tell if it's always been a bad starter, or perhaps was once good - then something got worn - and now it's bad. Sorry if that sounds confusing, but it's true. The variations in starting abilities were originally rooted in loose machining tolerances at the factory. Once in a while, an engine came though with every spec. at it's optimum level and it was a good starter. Then, one came through with every spec. at the lowest (worst) level, and it was a dog. Since then, Deere improved their rebuild kits in an effort to fix some of the old problems. With newer tractors, the machining tolerances got tightened up quite a bit (like a Japanese tractor or car). You need to figure, first of all, if the tractor is cranking fast enough. Very often hydraulic problems will slow it down and ruin starting. you can fix that with a manual pump destroker for just a few buck. That is often the #1 issue. Then, there are many other issues, i.e. and e.g. fuel delivery, fuel timing, valve depth in head, condition of combustion chamber, piston standout, etc. &c.
