Early Crawler ?
Gary_N_WV
11-21-2005 18:20:39
I know nothing about crawlers or John Deeres for that matter, I'm visiting from the red board.
I was talking with a friend who has a small JD crawler, that probably is pre 1960 and very small.
From reading a little here, I'm thinking it might be a B or MC.
One of my questions is: do these crawlers have standard tractor engines, or are they special for the crawlers.
I want to go look at the crawler because it is for sale and I'm trying to learn a little before I go.
Any information as to where serial numbers are or what to look for to help identify what it is will be appreciated
Thank you for your time.
Gary
jd51mt
11-22-2005 08:00:27
 Re: Early Crawler ? in reply to Gary_N_WV, 11-21-2005 18:20:39
Gary,
The first all deere crawler was the MC. It had the same engine as the model M and MT. The serial number will be on the instrument panel on the light-ignition switch plate. The MC used a three roller track. These are the year and serial numbers for the MC. Good luck. 1949 10001-11092
1950 11093-13373
1951 13374-15340
1952 15341-20509
MIke
jdemaris
11-22-2005 18:48:55
 Re: Early Crawler ? in reply to jd51mt, 11-22-2005 08:00:27
MC isn't quite the first. Lindeman company was making conversions of Deere tractors into crawlers starting with the D in 1931, then the GP, and then the BO around 1939. The BO was a Deere factory-authorized crawler - so I guess it's just as fair to call it a Deere as we do the early prototype L that used a Novo engine and Ford Model A transmission. Deere bought out the Lindeman Company and used some of their engineering to produce the MC crawler from the M wheel tractor in 1949. The Lindeman factory that Deere bought is where the track systems were built for the MC.
jdemaris
11-21-2005 18:46:07
Noting unique to crawlers as I recall. The two cylinder crawlers like the MC, 40, 420, 430, 440, shared their engines with wheel tractors. The first Deere crawler wasn't built by Deere at first - it was a kit to covert a B orchard tractor into a crawler - Lindeman. The first of the four cylinder crawlers around 1960 was the 1010 and 2010 series - same engines used in wheel tractors. Then, around 1966 - 350s and 450 came out with a new style engine - 3 cylinder 152 or four cylinder 202 - both used in wheel tractors like the 1020, 820/830 Manheim, 300 industrial, 2020, 2510, etc.
mjbrown
11-22-2005 17:04:40
 Re: Early Crawler ? in reply to jdemaris, 11-21-2005 18:46:07
I think the first Lindeman/Deere crawler was built on the GP chassis.
jdemaris
11-22-2005 18:25:03
 Re: Early Crawler ? in reply to mjbrown, 11-22-2005 17:04:40
It came in at least two versions, one on the GP and one on the BO (B orchard). I had two BO models.
old
11-21-2005 18:27:24
I think they used the same engine as some of the tractors did. I know there neat little toys. I own 2 of another green color crawlers
