Diesel in Crankcase Oil ~ JD350
Tracy Chesebrou
11-21-2005 12:43:59
Noticed liquid coming from crankcase breather tube on my JD350 dozer thought it was water, pulled off the pan and pressurized the cooling system found no coolant seeping from sleeves. Found diesel fuel in oil pan, anybody know where the diesel would come from?
Thankyou in advance,
Tracy Chesebrough
Tracy Chesebrough
11-22-2005 20:12:07
 Re: Diesel in Crankcase Oil ~ JD350 in reply to Tracy Chesebrough, 11-21-2005 12:43:59
Thanks for the advice. This gives me a place to start
Tracy
DAVISFARMS
11-22-2005 15:12:26
9 OUT 10 TIMES IT IS YOUR PRIMER PUMP THAT IS THE EASY FIX TO TRY FIRST AROUND $50 IF IT DOESN"T STOP IT THEN INJECTOR OR PUMP
95R-USER
11-22-2005 11:05:07
I've had this problem with a 275 massey tractor before. If your machine has a small hand operated priming pump mounted somewhere on the engine block this could be the problem. Mine had a rubber diaphragm leaking which in turn goes directly to the crankcase. I know this pump is used to bleed air out of the lines when changing filters but not sure what other purpose it serves.
D.P.M.
11-21-2005 16:53:24
If the 350 diesel has a fuel transfer pump that would be the first place I would check,Also could be from a leaking injection pump drive shaft seal.
