JD models with closed center hydraulics
Bill Grimley
11-11-1999 16:33:23
Can someone explain the difference between open center hydraulics and closed center hydraulics? I think I have heard that closed center is more advantageous for operating a loader, etc. - - -is that so? What older model John Deeres 50 horsepower or less have closed center? Thanks!
Mike H
11-11-1999 18:22:13
 Re: JD models with closed center hydraulics in reply to Bill Grimley, 11-11-1999 16:33:23
Open center pumps gallons of oil all the time at low or no pressure until you pull a lever.Closed center maintanes max. pressure with little or no flow until you pull a lever. Clear as mud? I see very little need for the small advantage of closed C.The 2010,3010,2020,4010,4020
2010 is open center-among many other faults
11-12-1999 06:36:03
 Re: Re: JD models with closed center hydraulics in reply to Mike H, 11-11-1999 18:22:13
That's my message.
Steve
11-11-1999 19:21:41
Closed center has a big advantage in power savings and prevention of heat in the hyd. system.
Mike H
11-11-1999 19:52:27
 Re: Re: Re: JD models with closed center hydraulics in reply to Steve, 11-11-1999 19:21:41
I disagree with Steve because on a JD it takes power to maintan the rated 2300psi standby pressure of a 4020, even with no flow!! And it seems funny about the heat question all of these tractors with closed hyd. have a OIL COLLER in front of the radaitor!!I have spent many hours with a flowrater hooked to these tractors trying to locate the monmentary loss of hyd.that occur from time to time and have found it!
Charlie
11-12-1999 05:28:20
 Re: Re: Re: Re: JD models with closed center hydraulics in reply to Mike H, 11-11-1999 19:52:27
Why does it take power to maintain the pressure if there are no leaks? It seems that it would be like pumping up a tire that after it reaches some pressure it keeps it with no more work. Not the same thing?
Mike H
11-12-1999 20:01:56
 Re: Re: Re: Re: Re: JD models with closed center hydraulics in reply to Charlie, 11-12-1999 05:28:20
I'll try to explain the JD C.C. hyd.pump there is a center shaft with a essentric cam on it with pistons surrounding this and with no pressure to start out the pistons follow the essentric cam and as pressure builds the pistons start to lift off the cam until the pressure is meet then they touch lightly to overcome the internal leakage and to fill any demand.(these pumps have no internal piston seals, so this is a built in leak ) this I described is more commonly known as going into stroke or destroking so to maintan the 2300 psi it has to pump under high pressure constantly hence power is used and heat is built up.Thats why a 4020 has that chattering sound when it's idling.I stand corrected on the 2010 there aren't very many of 2010's or 1010's in this area.
Gerald J.
11-12-1999 08:50:14
There are always leaks, especially the pump itself.
Gerald J.
