1968 4020 wiring diagram
robert motzing
11-20-2005 22:55:14
i'm looking for anyone who might have a wiring diagram for my 4020. having trouble blowing bulbs. bought a new resistor can't figure out all the wires though, have 24volts running to lights, need some help. thanks.
Tx Jim
11-22-2005 03:32:34
 Re: small ground wire ??? in reply to robert motzing, 11-20-2005 22:55:14
Robert,if it has battery cable crossing under floorboard to connect batteries check your rear bat post on LH side to see if it's grounded to frame. If it's not this can feed 24 volts to lights. Tx Jim
HTR
11-21-2005 17:45:38
 Re: 1968 4020 wiring diagram in reply to robert motzing, 11-20-2005 22:55:14
A little more information may help find the problem. Does it blow all four lights, or does it blow one on each fender, and the other two work right then. Does your oil pressure light and fuel gauge work? The only resistor in the lighting circuit is for dimming the lights for low beam road travel.
robert motzing
11-22-2005 15:02:22
 Re: 1968 4020 wiring diagram in reply to HTR, 11-21-2005 17:45:38
htr, thanks, it blows all four lights, but the back two still work. the oil pressure and the fuel gauge do not work. i have no dimming switch, the only switch i have is to turn lights on and off and there is three clicks on it. thanks robert
D.P.M.
11-21-2005 16:56:33
Try John Brillman www.brillman.com
1-888-274-5562
superfarmer
11-21-2005 16:48:54
If you can afford it, I would seriously consider converting it to a 12V system. It is a bit expensive, but when you're done you'll have a much better system to work on.
ET
11-21-2005 08:57:58
You may have an internal short in the starter. The starter may still work fine and still have an internal short.
