4020 and #1 / #2 diesel with cold weather
Nylon
11-20-2005 22:49:29
What has been your best methods in the cold with fuel. I know most guys dont like straight #1. I would like to hear a consensus of what has worked best for you guys. Especially those those that live north of Minneapolis. Montana Dakotas Wisc Mich Canada and such.
Thanks,
John
Bob
11-21-2005 22:35:05
 Re: 4020 and #1 / #2 diesel with cold weather in reply to Nylon, 11-20-2005 22:49:29
I'm in northern ND, where it gets COLD. From now 'till April, or so, I'll run straight #1.
No reason not to, and no chance of gelling up, just when I need the tractor the most!
What reasons have you heard not to run #1 when it's bitter cold outside?
jdjerry
11-21-2005 06:34:04
I live in N.D. and run a 50-50 blend of # 1 and # 2 fuel. I have never had a problem. I had better start blending or I will get caught this year. Hard to put in # 1 with 50 degree weather.
JDknut
11-21-2005 03:47:09
Up here on the Canadian Border near Quebec, it can go to 40 below. We cut the Diesel fuel 50-50 or 60-40 No. 2 and kerosene respectively, for both road Diesel and off-road. Also run a fuel additive like Power Service, this also helps prevent gelling.
mjbrown
11-21-2005 03:45:20
I use anti-gel in summer diesel which has worked well down to about the single digits F. Upstate NY
4020 guy
11-21-2005 05:57:20
 Re: 4020 and #1 / #2 diesel with cold weather in reply to mjbrown, 11-21-2005 03:45:20
Gee I'm in s dakota and maybe I'm going too far but years ago I had a tractor gel up .So I run straight #1 from thankgiving till april fools day.
donmyeil
11-21-2005 06:16:23
 Re: 4020 and #1 / #2 diesel with cold weather in reply to 4020 guy, 11-21-2005 05:57:20
yer right abt no. 1 . if you want your diesel to run, best go with it unless you have fuel heaters. you will lose a couple horses but you dont normaly need them anyhow this time of year.
4010guy
11-21-2005 17:48:20
 Re: 4020 and #1 / #2 diesel with cold weather in reply to donmyeil, 11-21-2005 06:16:23
up hear i like to run p40 which i think is an additive and it has never failed even at 40 below and by the way 40below is when u start to crack castings and graid 5 bolts.u wont hear anybody condoan it but if your gelled up and hav just got to get going pour in some gas in your tank as i hav seen truckers put in 5 gallons in thear tanks and it keeps them running for what its wourth but i am not reckimending it
Nylon
11-21-2005 23:12:48
 Re: 4020 and #1 / #2 diesel with cold weather in reply to 4010guy, 11-21-2005 17:48:20
Thanks for the great replys guys. I dont know why you couldn't run straight #1. I thought it had alot to do with lube issues and less wax in that fuel. I know that blending was common and most truckers can pull up and get blended at the pump. This 4020 is a 68 year class so no glow plugs or any of the advances of the last 40 years. Thats why I asked to see what the consensus was from guys who ran diesel tractors.
So Thanks Guys,
John
