2010 JD crawler/highlift?
DeereDiesel
11-20-2005 19:38:29
I was just curious if anybody has seen a JD 2010 industrial crawler highlift? I have a 1965 gas. It hasn't ran in at least 5 years and im trying to get it goin. I was just curious to know if anybody else has seen these anywhere. There was only 5 gas models made in 1965 and ive got one of them. I Think that is preaty neat. I cant wait to heat that 4 cylinder run again. It was my grandfathers and he used it alot to push trees. It has seen alot, I mean ALOT of use. I do know that he rebuilt it once. The old pistons are still in my barn. It stopped running one day in the field so he parked it in the barn and worked on it little by little until the day he died. It is my goal to get it running in honor of him. I am proud to say i got his old McColluch chain saw running today after 20 year of not getting ran. He used that saw alot, its an honor to be working on and using the equipement that he once used. Opps!!,, i kinda of got of track sorry! Well i will appreciate any help on getting the crawler running. I will say that i cant get spark, I replaced the coil, twice.. ah.ah, and the condenser and plugs and wires. i need to get new points and a new switch. The switch that is on there is off a lawn mower. Gosh i got side tracked again!!!! Well i would like to thank everybody on this board for being so helpfull, and any information on the crawer or any other questions that you guys have, i will be more than happy to answer. If you want to email me, my address is [email protected]. Once again, THANK YOU!!
jdemaris
11-21-2005 09:00:46
 Re: 2010 JD crawler/highlift? in reply to DeereDiesel, 11-20-2005 19:38:29
I don't know what you mean by a "high-lift", but I've seen and worked on many 2010 gas-engine wheeled forklifts and crawler-loaders. I never considered them rare, at least not here in central New York State. The igntion systems is not much different than any other - except: The original ignition switch had an igniton ballast resistor built into it. Later, Deere sold change-over kits to replace the switch with a more conventional type and installed a separate ballast resistor. Either way, both switches had their own built-in resistor bypass while in "cranking" position. If you have a Delco starter - and not the Prestolite, you don't need a special switch. Just use the little "R" terminal on the starter-solenoid as "R" stands for "resistor bypass." Deere Co. also insisted that the 1010 and 2010 use a special 6 volt coil, not a 12 volt coil. If you buy the correct coil, it can make a big difference in cold weather starting. If you install a generic 12 volt coil - with or without resistor, it's likely the tractor will not start well. The original Deere system, for some reason, used higher than normal voltage (or at least voltage potential), and it also caused premature igntion point wear. The Delco distributors and points lasted longer than the Prestolite or Wico.
