14mm Spark Plug reducers in 520LP with Elec. Ignit
Tyler-MO
11-20-2005 19:28:51
Hello Everybody,
I just installed the Petronix electronic ignition kit along with that HOT coil they sell from here at Yesterdays Tractors. The little devil of a plastic ring took some convincing to install on that distributor shaft, but once that was done it was cake. It made a major difference in how it starts, can't really tell with the overall running. I'm wondering if anyone has experience with thos 18mm to 14mm spark plug reducers and electronic ignition kits. Is it worth my money to use automotive 14mm i.e. platinum tip plugs or should I just stick to the good old 18mm plugs with a wider gap?
Thanks for any ideas/stories,
Tyler in Missouri
Mike Aylward
11-20-2005 19:48:26
 Re: 14mm Spark Plug reducers in 520LP with Elec. I in reply to Tyler-MO, 11-20-2005 19:28:51
Tyler, I have the adaptors in my 70 pulling tractor. The main reason I went to them was to get a plug with a longer reach for the Power Block in the tractor and to utilize a wider spark gap. In the other tractors I have installed the electronic ignition in I used the recommended plug and opened the gap. The problem I found is that you can only open the gap so far with the construction of the "normal" plug. So I went with adaptors and got a plug I could open up to .050" or more. I have an MSD box on the 70 so it can make lots of "fire". If the tractor will roll over one time it is running. Hope this helps. Mike
Mel in SW Iowa
11-21-2005 06:39:18
 Re: 14mm Spark Plug reducers in 520LP with Elec. I in reply to Mike Aylward, 11-20-2005 19:48:26
But Mike, your 70 would start on the first rollover with pts and condenser too, wouldn"t it?
Seriously, if I put higher compression pistons in my 720 gas, will it be harder to start unless I go to solid state ignition?
Do you have to convert over to negative ground to use an MSD box. Which box are you using? Does it show any difference on the dyno?
Are you using a dry air filter? How did you convert it?
Thanks,
Mel
Mike Aylward
11-21-2005 10:24:47
 Re: 14mm Spark Plug reducers in 520LP with Elec. I in reply to Mel in SW Iowa, 11-21-2005 06:39:18
I doubt if my 70 would even fire without the setup I have on it. It has about 10:1 compression and I figured it needed all the fire it could get. I doubt if you will have as much compression in your 720 as this thing has but you will definitely like the electronic ignition. More dependable starts in all weather conditions, smoother idle, and no point wear or degradation. To me it's a "no-brainer" whether or not to use it. I have an MSD 6 box on the tractor (bought it used) and it works good. You do have to convert to negative ground with it but that is no big deal. I have a dry air filter on the tractor of my own manufacture. It is a common John Deere filter but I did all the plumbing for it and feed each cylinder with a separate pipe. I haven't had it on my dyno because it is temporarily "laid up" and I haven't had time to get it fixed back up. Lots of rambling, but hope it helps. Mike
Mel in SW Iowa
11-21-2005 18:19:28
 Re: 14mm Spark Plug reducers in 520LP with Elec. I in reply to Mike Aylward, 11-21-2005 10:24:47
Mike,
I want to keep my 720 so that I can do fieldwork,
so I imagine I"ll need to stay down around 8.5:1.
If time and funds allow, I"d like to try zero gap rings on it, but I"m not sure the results would be any different than simply starting with a higher static compression. Both should result in higher cylinder pressures.
I"ve used MSD boxes on street driven vehices and
liked the results, but never dynoed the results.
I have always thought that they should be more effective at 2 cylinder rpm levels than on higher speed motors, so I bet you"re on the right track.
Are there any dry filter canisters that might work to easily replace the oil bath?
Thanks for the coaching,
Mel
Mike Aylward
11-21-2005 18:32:19
 Re: 14mm Spark Plug reducers in 520LP with Elec. I in reply to Mel in SW Iowa, 11-21-2005 18:19:28
My good friend buickanddeere can give you the address of Albert at Renaisance Tractor. He makes a dry air filter conversion for these tractors. Mike
Mike Aylward
11-21-2005 18:28:27
C B Mier
02-15-2008 12:13:31
 Re: 14mm Spark Plug reducers in 520LP with Elec. I in reply to Mike Aylward, 11-21-2005 18:28:27
I am looking to reduce my 18 mm sparkplugs to to 14mm. Can anyone tell me where to find the reducers. I have seen them, but it was years ago.
Thanks in advance for any info. Chuck
