3010D Generator light stays on
MaverickM23
11-20-2005 19:20:18
Recently the GEN light on our 3010D won't go out. Once the tractor is started it stays on no matter what RPM you run it at. This spring i replaced the starter, key switch, and light switch and ran it all summer with no problems. I checked the generator and it seems fine, not sure what else to check out.
John T
11-21-2005 13:17:09
 Re: 3010D Generator light stays on in reply to MaverickM23, 11-20-2005 19:20:18
Mav, see if when you dead ground the gennys Field post to case she charges????? If so but NOT otherwise, its EITHER a bad VR or a poor VR ground or the wires open from the VR"s Field terminal to the gennys Field post. If still no charge, leave the Field grounded n by pass jump the VR"s internal Cutout Relay by jumping the VR"s BAT and GEN (or ARM) terminals together n see if she charges then?? If so but not otherwise, the VR is bad (bad cutout relay). With BOTH those by passes the VR is essentually out of the circuit, so if she still dont charge then AND IF ALL OTHER WIRING IS GOOD AND BATTERY IS OKAY, the genny must be bad. Be sure belt is tight and the genny n VR both have a good ground.
John T
HTR
11-21-2005 15:09:07
 Re: 3010D Generator light stays on in reply to John T, 11-21-2005 13:17:09
John, 3010 diesel is 24 volt isolated ground. If you short field terminal to case, you will have a 12 volt short, key on or off engine running or not. You can full field the generator, by hooking a jumper from A2 terminal and field terminal,and then check voltage from A1 terminal to A2 terminal.
John T
11-21-2005 19:07:20
 Re: 3010D Generator light stays on in reply to HTR, 11-21-2005 15:09:07
Oops, thanks HTR, I missed the D on the end and was thinking 12 volt gasssss ssss. Im more into the older gas 6 n 12 volt stuff. THANKS FOR CATCHING THAT
Take care yall
John T
Matt_In
11-21-2005 08:30:43
My 3010 does this from time to time. The points stick in the regulator. I usally just take something out of the tool box and hit the cover on the regulator and it will work again for a few more months until they stick again. I am no expert but I would check your regulator.
MaverickM23
11-21-2005 12:38:37
 Re: 3010D Generator light stays on in reply to Matt_In, 11-21-2005 08:30:43
Thats what I'll try next. I looked at regulator when looking at the generator and it looks like it might need replaced soon anyway. Thanks
