4230 john deere
wkk427
11-20-2005 18:48:58
what would make the boots on the return fuel lines build up pressure and bust could a stopped up fuel filter cause this the tractor has started running really bad and all of a sudden it will level off and run great the only problem is when it does this it will have a leak in one of the return line boots thanks far any help
cannonball
11-21-2005 02:47:58
 Re: 4230 john deere in reply to wkk427, 11-20-2005 18:48:58
a blocked return to tank.. the return lines from injectors all have tee's and run from one to the other and the last one(front i beleve) goes to the fuel tank, it must be stopped up... have nice day may god bless
wkk427
11-24-2005 19:25:01
 Re: 4230 john deere in reply to cannonball, 11-21-2005 02:47:58
i found a plugged line from the bypass lines to the fuel tank . thanks far the info
wkk427
11-21-2005 04:07:20
thanks i will check that
