4020 ether line location on manifold?
Nylon
11-20-2005 17:55:16
I have tracked my ether line from behind the dash to the left side where I have found that it comes to an end at a small threaded nut "turnbuckle" right above the starter. This explains why I haven't been able to open my ether cap on the dash. I bet someone locktighted the thing.
I am wondering where this line is supposed to go exactly on the intake manifold. I am guessing that it is plugged but want to make sure. I found a small line that looks like it was clipped up near the front / radiator end of the intake manifold on the inside / engine side of the manifold. Is this where that line is supposed tie in or did it just depend where someone stuck it? btw it is a 68.
Thanks,
John
Bob
11-20-2005 19:35:05
 Re: 4020 ether line location on manifold? in reply to Nylon, 11-20-2005 17:55:16
third party image
IIRC, where plug #3 is shown in manifold key #2A.
There is a similarly located tapped port in other versions of the intake manifold.
Nylon
11-20-2005 22:45:33
 Re: 4020 ether line location on manifold? in reply to Bob, 11-20-2005 19:35:05
Bob,
Thank you very much. That location on the diagram is where a line that leads out of that plug hole is pinched off. That is where that dead end line splice would have gone to. It was intensionally removed. And I think the cab ether cover was locktighted. They must have had problems with ether use at one time. It had been cold several days and warmed up to 30 degrees today and it started right off with no preheat. It was sitting in the sun though. I will try to see if I can make it without ether and see how it goes. I have about a 50/50 consensus on ether so far but damage due to ether vs no damage and no start is more appealing.
Thanks again,
John
Glen Anderson
11-21-2005 17:24:38
 Re: 4020 ether line location on manifold? in reply to Nylon, 11-20-2005 22:45:33
Ether used properly as a starting aid will NOT harm an engine. We have been using ether for over thirty years on our 20 series tractors(2 4020s & 1 3020) and have not damaged an engine yet.
Starting fluid has to be used sparingly and carefully. Especially carefully on systems that utilize an atomizer system in the intake manifold.
To use ether/starting fluid properly, begin by cranking the engine and waiting for the starter to bring the engine up to its fastest cranking speed(having an engine cranking over slow with a poor starting system and using ether is a no-no, the engine will likely lock-up) Once the engine has reached its full cranking speed quickly push and release the ether can into it's injection point under the dash and wait to see the engines response. If the engine takes off, great, if not give it another very quick shot and so on.
The key is to use the minimum amount of ether that is absolutely necessary to start the engine and to keep cranking speed as high as possible. If you adhere to these simple rules you will have a viable starting aid to assist you during cold weather start-ups where perhaps conveniences like block heaters or heated shops are not an option.
Nylon
11-21-2005 23:24:35
 Re: 4020 ether line location on manifold? in reply to Glen Anderson, 11-21-2005 17:24:38
That is good info. I do have a tank circulating heater i think it is 1500 watts. I just didn't know if it would be enough to actually get a start when pretty cold. I am not going to force a start on my tracter when it gets stupid cold. But there are times wher it has been 30-40 below and it warms up to -5 for weeks on end and somewhere in there I may need to get a start. I don't know if a tank heater will start it at -5 alone. I have started this tractor with no heat
@ 26 degrees and it almost was no different than starting at 70 degrees. It stumbled a tad but not much. I could easily install an ether line just for insurance. I am a big believer in judicial usage. I will certainly be using heat long before I reach to a can of ether. My rig is a 12 volt system and has large wires and it spins over very strong. It has been long time since I have heard a 24 volt turn over but I would bet this 12 v isn't far off. Thanks for the info
John
