2510 Clutch Stuck
Paul in WI
11-20-2005 17:31:39
I have a 2510 we restored a couple of years ago. We ran it a few times this summer but it sat for the last 3-4 months. The other day I went to move it, it started great but the clutch would not Dis-engage. Putting the clutch in does not Dis-engage it. I removed the bottom inspection plate, everything seems to be working. The throwout bearing engages the clutch levers and there appears to be plenty of travel in the clutch levers. Could the clutch be plate rusted to the clutch disk....it doesn't seem like that could happen in such a short time, I am grasping here.
The clutch worked fine when we parked the tractor 3-4 months ago. What am I missing? I would just as soon not split the tractor if it is something simple.
Thanks for any help. Paul
Paul in WI
11-20-2005 18:59:29
 Re: 2510 Clutch Stuck in reply to Paul in WI, 11-20-2005 17:31:39
Thanks, I will try this tomorrow night. Thanks again. Paul
MSM
11-20-2005 17:41:21
Disc has probably rusted to the flywheel.If you can safely get it started in gear,hold the clutch down and hit the brakes,if its lightly stuck this usually works.
