torque specs of a john deere a
johnny A
11-20-2005 10:18:06
i need torque specs for the rods on a 1949 A i know that i need to do the plasti gauge but i need to know how tight to get them??
Duane Larson
11-20-2005 19:31:51
 Re: torque specs of a john deere a in reply to johnny A, 11-20-2005 10:18:06
Johnny,
Torque on the rod caps is 100 ft-lbs, according to JD Field Service Bulletin 186. Tighten them to 100, then enough further to be able to insert the cotter pin in the slotted nut.
Plasti-gage works well when your crank has been machined so it is round. If that is not the case, clearance measured by the plasti-gage will depend on whether you happened to place it on a low or high point on the crank.
buickanddeere
11-20-2005 11:28:14
1-800-522-7448
