Baling problems
idontno
11-20-2005 09:36:30
How can I get my 535 baler to pickup tall sorgrum (feed)? It wants to stand up in the chamber and not start to roll.I have tried slow speed,slow rpm,fast rpm and speed.Belt are good.Small feed will go right in and start.I have been putting the first 10"of the windrow sideways and it will start up ok then.But I don"t have time to get out and move it for every bale.Please help I got 200 acres to go....
jdjerry
11-20-2005 15:21:46
 Re: Baling problems in reply to idontno, 11-20-2005 09:36:30
I just welded a bead on the square stock on the starter roll. It squared the edge up and it works great. It also fixed my neighbors New Holland.
Tx Jim
11-20-2005 09:53:21
idontno,was the hay crimped? Are you running pick-up teeth as high as possible? Are MANY teeth broken? Are you running hyd's at lower than max. pressure? JD offers a kit that lowers the core pressure to aid difficult starting problems. How many bales has this baler baled? If leading edge of metal bars on starting roller are worn you can help starting by welding on rectangular bars!!! Email me if none of these help, [email protected]
430WLPG
11-20-2005 12:24:37
 Re: Baling problems in reply to Tx Jim, 11-20-2005 09:53:21
I agree with Tx Jim we had the same problem until we welded new square stock on the starting roller,it doesn't take as much wear on the square corner to cause trouble
idontno
11-20-2005 16:32:22
 Re: Baling problems in reply to 430WLPG, 11-20-2005 12:24:37
I think the sqaure bar are worn some.Not bad.I am going to weld a bead on the leading edge and see if that will help.The baler has around 5,000 bales on it.Thanks for the imput guys....idontno
