JD 2440 Info
Carl Ernst
11-20-2005 09:17:26
I just purchased a JD 2440 D late model and would appreciate any info from the forum regarding the following:
1. Where can I purchase an Owners Manual?
2. What is the yellow knobbed handle between the two trans shifters?
3. The spring in the parking brake handle is broken. Is there a simple fix and are these parts still available from Deere?
4. The diff lock peddle is extreamely stiff. How do I free up the linkage?
5. There is a small rubber push knob below the ignition key. Is that an ether setup and is it ok to use ether? 6. Are there glow plugs or an intake air heater on this tractor?
7. There is a small switch or releif valve cap on the right floor of the center console. What is that?
Thanks in advance for all your help.
Glen in TX
11-20-2005 09:41:59
 Re: JD 2440 Info in reply to Carl Ernst, 11-20-2005 09:17:26
JD will have the parts, operators manual, parts manual and tech manual through your local dealer or calling 800-522-7448 or visiting their publications site. The I&T shop manual may be available here at YT or many other tractor supply vendors. You can also search the parts book for it online at http://jdparts.deere.com
