1940 B Governor / Fan gear backlash
Jason Z in MO
11-20-2005 08:25:11
third party image
I have rebuilt the fan and governor on my 1940 B, sn 81291. Set the proper heal but not so sure about the backlash.
The SM-2004 manual says .004" - .007". The gears are used but in decent shape. The tractor sat for long time so the gear teeth faces are not shinny from running but I have cleaned them. I can either get .006" or removing the thinnest gasket it drops to .003".
I don't know how much break-in will occur with these gears or how much backlash should be set with used gears; suggestions?
Thanks!
Mike M
11-20-2005 18:57:01
 Re: 1940 B Governor / Fan gear backlash in reply to Jason Z in MO, 11-20-2005 08:25:11
Those gears do look really good for used.look about like new. Did you rotate it and check the clearance at different spots ? They usually change. You are better off to error on the side of loose as too tight they will sing and never get quiet.
Jason Z in MO
11-20-2005 19:28:30
 Re: 1940 B Governor / Fan gear backlash in reply to Mike M, 11-20-2005 18:57:01
Mike,
Thanks for the advice. I always try for the closer tolorance but I need to learn when its not always good. I have read a lot about these gears causing noise but I don't have any experience with them. Actually I didn't measure in different spots but I did rotate by hand and didn't feel much change. I will measure it tomorrow. Regardless, I will make sure they have a little "play".
You said the gears look good... I have been very pleased with how well all the parts look in this tractor. The guy I bought it from was thinking about parting it out. It would have been worth a WHOLE lot more than I paid. But cosmetically looked pretty bad. I have a picture of the crankshaft flywheel slines, they look so good I hate to bolt the flywheel on and cover them up!
Mike M
11-21-2005 10:41:14
 Re: 1940 B Governor / Fan gear backlash in reply to Jason Z in MO, 11-20-2005 19:28:30
I parted out alot of tractors in the past. And while you can make some money with them you have very few things that sell real well so you end up with alot of stuff no one needs or wants. At the prices I see mostly complete "parts" tractor sell for I wish I would of just stuck mine in a shed and then resold them complete at a later date i think I'd been money ahead. And not to mention my back may of lasted longer from not handling all those parts.
Duane Larson
11-20-2005 17:15:43
Jason,
A WW-II Service Manual I have from the Columbus branch house recommends a movement at the fan tip of 1/4" to 3/8", while my I&T book recommends a fan tip movement of 1/8" - 3/16". Both of these fan tip movements are larger (by more than a factor of two) of what one gets by calculating the tip motion corresponding to the gear movement of 0.004-0.007. So, you can take that info for what you deem it's worth.
Your gears appear to be in good shape, so I doubt there would be much change in the heel/backlash after an hour of running. I recently changed out the fan gear on a late A (the driving gear was in much better shape for some reason), and I used a magneto coupling hooked to my electric drill to run the governor/fan system to "mate" the gears and get rid of some of the noise. The heel did change a bit so I changed some fan gaskets. Using some bluing on the gear teeth to check the wear pattern, it was clear the gears meshed much better after about 45 min of running, and the system became much quieter. So, if you fabricate a mechanism to drive your governor you can learn something - but that is up to you.
Jason Z in MO
11-20-2005 19:18:36
 Re: 1940 B Governor / Fan gear backlash in reply to Duane Larson, 11-20-2005 17:15:43
Duane,
Based on your service manual, it sounds like loose is better than tight... I think I will stick with direct measurement of the backlash.
Excellent idea on driving it with a drill! I packed all the bearings to pre-lube them but do you run the gears dry so they mate quicker? How did you support the drill while it was running? I suppose you could leave the magneto mostly intact, pull points plate etc and "chuck" it up to the magneto shaft.
Duane Larson
11-20-2005 19:52:40
 Re: 1940 B Governor / Fan gear backlash in reply to Jason Z in MO, 11-20-2005 19:18:36
Jason,
Initially I sprayed the gears with bluing and ran them a few minutes, checked the wearing spots on the gear faces, resprayed, etc. until the wear pattern began to settle in and the gaskets were mostly adjusted. Then I wiped on a little white lithium engine assy grease with my finger (to keep from slinging it all over) and ran the system 10 min at a time, then inspected. I didn't use grease initially as the bluing won't stick and the gears did wear a bit faster - not enough dust was generated to get into the other bearings, or at least that I could observe from rags, etc.
I have a coupler made from a socket adapter which has a hex rod on one end (to connect to the drill) and a 1/2" female on the other. After turning a shoulder on a piece of 1/2" square stock to align with the hole in an old drive cup, I welded it to the drive cup, and connect it to the socket adapter. I use an old, heavy duty 1/2" 500 rpm drill which has a long rod screwed in the case for a top handle. Some propping and a clamp holds it in place. There is a fair amount of torque required to drive the system with the fan running. The whole unit was placed on a large steel table that wasn't going anywhere!
If you couple your drill to the magneto shaft, I would try a short, stiff piece of hose to couple the magneto to the drill, as it is hard to stay on the center line of drill/magneto rotation and easy to introduce nasty off-center torques which could be hard on the magneto.
xragman
11-20-2005 09:48:52
very good pic. you should be good at .006 backlash.
