3020 brakes
jam in pa
11-20-2005 08:18:39
I have a 1966 3020d. the left brake has become very hard to operate but seems to work. When the right brake is pressed , it seems to stop both tires.
Are there certain parts I should be looking at replacing in the brake vavle?
jeff-pa
01-05-2006 09:39:30
 Re: 3020 brakes in reply to jam in pa, 11-20-2005 08:18:39
I got the boots and push rods and o-rings installed and it works like new. both pistons where rusted so I polished them up.
It would have gone alot smoother but some previous owner welded the pedal pivot rod in instead of drilling and adding a cotter pin. The rod is no longer available from JD, I was able to save it.
donmyeil
11-20-2005 17:08:13
Look at the boots on the brake valve . would bet the boots are cracked and letting in dirt. Remove the pins on the pedal clevis. support the brake valve underside with a post jack, and remove the three cap screws that hold the top cover on. you will see the trouble is one of the pistons is stuck down. remove them, clean or replace and replace the 2 o-rings and get boot kits for the boots. After reasembly measure the center of the pins from the top of the valve for 3 in. to center of pin. start engine and bleed brakes at top rear of rear axel.
msb
11-20-2005 17:32:39
 Re: 3020 brakes in reply to donmyeil, 11-20-2005 17:08:13
Could also just be the pedal pivot pin rusted up.
jam in pa
11-21-2005 07:33:46
 Re: 3020 brakes in reply to msb, 11-20-2005 17:32:39
Thanks much.
You are correct, the boots are not good. I tried shooting wd40 into them about 6 months ago but no luck. I will take it apart and try to free it up.
I think I have the part number for the rebuild kit somewhere.
