1 bottom trip plow
gth
11-20-2005 06:30:12
I have a JD 1 bottom trip plow and was wondering has anyone ever rebuilt the clutch on one of these? Sometimes when I pull the rope to bring the plow out of the ground I have a had time doing it. thanks for any info
Gerald
Maark
11-20-2005 07:53:08
 Re: 1 bottom trip plow in reply to gth, 11-20-2005 06:30:12
Pull the wheel and hub assembly off the clutch side, you will find a linkage with a roller on it. More than likely rust has caused the roller to become stuck. I use an acetalene torch to heat the parts up hot to break the rust and get everything moving inside. Then take the pieces apart, coat with neverseize and put it back together. Make sure you have a good return spring. A scraper spring from a JD 230 disc works very good. Make sure the sleeve that rides up and down on the rod from the depth adjusting lever is also free.
