49A timing revisited.HA HA(fixed)
Jak
11-20-2005 06:16:22
I finally got time to get to working on the A and messed around and fixed it.John T said the flywheel halves should be horizontal(flat across) on number 1 on compression stroke on the flywheel and it was.He said the distributor side with distributor off should be horizontal as well and thats where the problem was.It wasn't even close to being horizontal.I pulled the governor cover on the flywheel side and found a mark on both gears that were not even lining up with each other.I pulled the governor shaft out and moved it about 6-7 teeth to get em to match.That distributor is pointing correctly now and it started right off with #1 plug not even in it yet.I installed #1 plug and away we went.I have found out it does have a 60 flywheel on it through all this process.I love it,and I can't deny it,I don't know what I'd be doing if it werent for these old relics.Jack(TN).
John T
11-20-2005 09:06:20
 Re: 49A timing revisited.HA HA(fixed) in reply to Jak, 11-20-2005 06:16:22
Cangratulations Jak, glad to hear you got the old girl popping. Heyyyyy yy you callin me an "Old Relic" or you mean the tractor lol
John T
