JD 2030 Engine Overhaul Help?????
Ponchobro
11-19-2005 16:18:42
Hello, I am getting ready to install new piston's and liner's in my JD 2030. Do I need any special tools to install the liners in the block?? Thanks for the input!!!!
Charlie1520
11-20-2005 17:23:00
 Re: JD 2030 Engine Overhaul Help????? in reply to Ponchobro, 11-19-2005 16:18:42
I changed the sleeves on my JD1530 and built a home made tool to get the old ones out. It was pretty simple. I got a piece of continuous threaded rod from the hardware store. I then took a piece of 1/2" or 3/8" metal about 1 or 2 wide and cut it so that it was just a little wider than the cylinder opening. I drilled a hole in it and spot welded a nut on the back side so that the rod would go though the hole and thread with the nut on the other side. With the rod separated I could put the metal bar down the cylinder with my hand and turn it so that it would catch the lower part of the sleeve I was wanting to remove. Holding it with one hand I would thread the long rod into the nut plenty to hold it.
Then on top I put another metal bar also with a hole drilled in it slightly larger that the rod. This top bar was longer so that it would extend beyond the edges of the sleeve. Put another nut on the rod so that this top bar can be screwed down. Now placing some kind of spacers between this top bar and the block (I just a couple of large nuts) the top nut can be tighted which pulls the sleeve up. Since the sleeve did not come completely free with just one set of the large nut spacers I ended up using a second set but that was enough to get the sleeves up high enough to pull out by hand.
I hope this helps and was not too confusing.
jdemaris
11-20-2005 05:24:42
No special tool needed to put them in - but sometimes you need one to get the old ones out. Most important when installing the new sleeves - once all the old sealing rings are removed from the block, and you've cleaned it up, BEFORE you put the new sealings rings in - try installing the sleeves. They should easily drop into place, or at least go in wish a light push, If they don't - clean things up so they do. Otherwise, once the new sealing rings ARE installed, and a sleeve goes in hard - you won't know if the interference is caused by dirt and corrosion - or by something amiss with the sealing rings. When all it right, put some soap on the sealing-rings and sleeve - NOT oil. Then, just push into place. The reason why oil is not to be used is - one of the sealing rings (the orange one) is designed to swell the first time it makes contact with oil.
lonzo
11-19-2005 23:16:55
to save alot of hand work i use small round wire brush welded to a 1|4 rod and use a drill to clean out the oring area in the block, fallow the instructions that come in the sleave box
