JD 3010-D Hydraulic poblem, need help!!!
bonerack
11-19-2005 13:57:17
I have been having trouble with my hydraulic system. When I raise my draw bar, it shakes. I changed the Tran/Hyd filter. Changed all 10 gallons of fluid. CLeand out the Tran catch screen.
My question is do I need to bleed the air out of the hydraulic system? If so how do I accomplish this? It still shakes by the way.
Tx Jim
11-20-2005 04:05:18
 Re: JD 3010-D Hydraulic poblem, need help!!! in reply to bonerack, 11-19-2005 13:57:17
bonerack,does steering work good? If so check stand-by pressure. It should be 2250 psi. Was trans screen clean? Priority valve for brakes and steering could be blocking flow. Could have bad valves in main pump. I will not use any snake oil in my JD hyd. system!!! Tx Jim
jd9295
11-19-2005 13:58:58
try the lucas brand hyd. oil treatment.
bonerack
11-19-2005 16:56:16
 Re: JD 3010-D Hydraulic poblem, need help!!! in reply to jd9295, 11-19-2005 13:58:58
what will adding this product to my hydraulic oil accomplish?
Thanks for your response!!!!!
