Generator voltage????
Billy C.
11-18-2005 16:26:30
I have two generators that did not come on my "H", but don't know if they are 6 or 12 volts. Both will fit bracket, but I need to know voltage before I order lights and a battery. Anyone know a way to check? I can put air wrench on pulley nut and spin them, but how do I check to see what they are putting out? Thanks
Mark Scholten
11-19-2005 04:39:32
 Re: Generator voltage???? in reply to Billy C., 11-18-2005 16:26:30
Take them to your local NAPA store or auto electric rebuilder. They will bench test them and tell you if they are 6 or 12 volt and also if they are any good.
Mark
John T
11-18-2005 18:30:01
Billy, if you ground the Field and spin them, the open unregulated output voltage on the Armature terminal with respect to frame ground would rise much higher then if loaded and regulated. Regardless, if spun at the same RPM the 12 volt should read higher then the 6. I have some limited Delco specs if you happen to find any tag data.
John T
P Browning
11-18-2005 17:39:49
Billy -- do you have Delco part numbers from those generators? Post them if you do. Someone should have the documention to tell you more about them. I may even have it. (PatB)
Billy C.
11-18-2005 18:08:52
 Re: Generator voltage???? in reply to P Browning, 11-18-2005 17:39:49
Pat, I don't have Delco number here at home. I will get it next week when I go back to where they are. One of the generators does not have a tag on it. Billy
Arthur Driesse
11-18-2005 16:38:40
Just my thoughts, Try wireing them to a 12 volt bulb, if it glows bright it is probably 12 volts if it glows orange then its probably a 6 volt unit. Also make sure that your air tool is spinning at the right rpms.
