Jak, can you remove the left plug and use a wire or something in the cylinder to determine when the left piston is at TDC????? If you get it there then see where any flywheel marks are lining up??? When the left piston is at TDC, the distributors rotor tip shoud be pointing to where theres an internal pick up inside the distributor cap for the plug tower wired to the left cylinders plug. Then 180 of crank rotation later (right piston at TDC) the rotor tip should be lined up with the internal cap pick up to the tower to the right cylinders plug. Also, I believe the cutout slot in the flywheel should be tracking with the female drive slot in the end of the governor shaft which drives a mag or distributor ANDDDDD D when the left piston is at TDC, that flywheel slot PLUS the female slot on the governor shaft end (where mag or dist mates) SHOULD BOTH BE FLAT HORIZONTAL FORE N AFT. If the wires are crossed, get them so the above paragraphs hold true n she opught to be somewhere close. Left piston fires at TDC then 180 degrees of crank n flywheel rotation later, the right fires, and the rotor tip needs to be lined up at firing time with the cap tower to the correct plug. Is this a flywheel cover with a removeable small center??? If so, find a dot on the bottom of the flywheel hub that lines up with a mark in the bottom dead center of the flywheel cover. Thats when the left piston is at TDC Im pretty sure. I mess more with open flywheel tractors Clear as Mud ????? John T
