1966 3020
Kurt Keeler
11-18-2005 07:16:54
I recently bought a 3020 and it is apparently one of the "hard starters". The dealer is working with me on the problem and I think they are going to make things right,,,, but the service manager asked me if I wanted to keep this tractor. I told him yes,,,,, I"m wondering if that was a mistake. I was looking for a utility tractor (30 hp or so) to blade gravel and snow. Also to move some dirt around and clean up a bunch of junk around the place.
After shopping around for quite awhile it became apparent that if I went up a size or two I could spend the same money and get a tractor in the same or better condition.
Are there other issues I should be aware of with this year/model that I should consider before I tell them I want to keep it?
I didn"t want a tractor to work on,,, but rather one to use. Is this not possible without spending $20 - $25 K on a new one?
kurt keeler
11-22-2005 05:44:58
 Re: 1966 3020 in reply to Kurt Keeler, 11-18-2005 07:16:54
Thanks to everyone for their help. Seems that a combination of Sea Foam, new gas and closing the choke all of the way (I still need to adjust the cable) looks like it is going to fix the starting problem.
The hyadraulic pump is still dragging it down during startup,,,, is there some good info in the archive about where to get and how to install the ?manual over-ride switch?. I'm not sure what you call it or what to search for.
Heat Houser
11-19-2005 16:52:25
My 4010 gasser was a hard starter thursday, 7 degrees F. I had "summer" gas in it, (filled the gas barrel last summer) and could only get it started by heating up the carb to get the gas to vaporize. (Used the wife's hair dryer to avoid open flame) Also, the last time I replaced the starter, I used an LP starter. LP engines are higher compression and take a larger kw starter. It will spin over a lot better and start easier with the LP starter.
1playfarmer
11-18-2005 18:15:22
I bought my 3020 gasser this spring and it was hard to start in the fact that it would run out of battery(new) if it didn't fire up right away. I replaced the plugs new wires eltronic igition, all of these helped but what really made the difference was adding a 1000 crank truck battery on the right side. I left the other battery in also and ran seperate cables to the starter. now it starts good. Good luck.
Mike M
11-18-2005 09:17:32
They must of missed something on that tune up ? Those gassers should fire right up and the colder it is the better they start. When I got the 4020 about 12 years ago now the first thing I did was give it a proper tune up.This included compression check,adjusting the valves,new cap,rotor,wires (make sure they have wire in them ! ),points and cond.and setting the timing among other things. Haven't had to lay a wrench on it since except for last year it needed a new transfer pump.
Kevin L.
11-18-2005 08:03:29
if you really want the tractor then replace the point and condensor with the $100 to $150 electronic ignition system if the problem seens to be in that area will solve alot of headaces on a cold morning.
Kurt Keeler
11-18-2005 07:33:05
Sorry, its a gas. They supposedly "tuned it up" before they delivered it,,,, but it started fine when I drove it at the dealer. Now it doesn't want to start at all.
They supposedly put in new points, plugs, etc.
fixerupper
11-18-2005 10:29:52
 Re: 1966 3020 in reply to Kurt Keeler, 11-18-2005 07:33:05
Does the choke close completely? If it is open the slightest amount, the tractor will not start. With the choke button pulled all the way out give the choke shaft on the carb a little twist with a pliers and see if it closes a little farther. Had this happen on a 4020 gas engine in a 105 combine. Good luck. Jim
G/MAN
11-18-2005 10:27:32
Take it back and make them do it right. If it started well before the tuneup and not after, it's obvious that something isn't right. The guy that mentioned an electronic ignition set-up is correct. Spark-ignition New Gen Deeres start much better with an electronic set-up, have better throttle response and maybe a skosh better fuel economy.
Hayfarmer
11-18-2005 07:29:55
The 3020 was a good tractor and should not be a "hard starter" especially. You didn't say if gas or diesel. The diesel would be a 24 volt system unless changed over. There could be any number of problems including lack of compression, injector pump timeing, injectors or even drag from hydraulic pump. On a gas engine it could be carb,points and condensor or drag from pump. For what you want to do in my area you coudl probably pick up a 2030 or 2630 for about the same price and they are a little smaller.
G/MAN
11-18-2005 07:29:22
Gasoline, diesel or LP? Does it crank hard or crank fine and just not start right away? Depending on the fuel type, could be anything from a $20 fix to a $1000+ fix.
dozerman
11-18-2005 15:04:42
 Re: 1966 3020 in reply to G/MAN, 11-18-2005 07:29:22
Just jerk the steering wheel back and forth while cranking. It's a John Deere trait on that series tractor. This dumps the pressure relief valves. The engine turns over easier and fires off quicker. Points setting is critical on the 3020 also. It's a keeper.
