DEERE NOT STARTING
IRON MULE
11-18-2005 07:15:09
Well guys I have a jd 440 2cyld. and just rebuilt it and it will not hit I got it to backfire a few times and hit on the second cy. but it was more like a cough and then my batt. died off to much to spin good the carb. had flooded on me and float is taking on gas now so I have to get new on and charge batt. it has new points and plugs and wires has good blue/to white acr on plugs any advice to make her purr to hear that johny poppin would be great thanks in advan. IRON MULE
Mike M
11-18-2005 07:24:42
 Re: DEERE NOT STARTING in reply to IRON MULE, 11-18-2005 07:15:09
Best tip I can give is that when rebuilding an engine do the starter,carb,dist.,water pump and everything else that's connected to it. It's going to turn harder and run hotter now so everything else needs to be in top shape.Your new plugs may be junk now if they got wet too.
G/MAN
11-18-2005 07:21:18
Timing? Plug wires in the right location?
IRON MULE
11-18-2005 08:03:32
 Re: DEERE NOT STARTING in reply to G/MAN, 11-18-2005 07:21:18
Yes the plug wires are in the right place as I have chcked and rechecked because I am bad to forget and do things backwards the 1st cy. is hooked to the 1st spot the button comes to via. the maneul and I timed it to the i&t shop manuel that said to turn the dis. cam foward and houseing backward when the points just start to open when the spark mark on the flywheel is alined to the timing hole. set gap the points to .022 and the plugs to be gapped at .025 and I took the valve cover off to recheck the gap of the valves to .015 and to spin it over to make sure the valves where in fact moveing and not stuck the head was redone by a head shop and I got new valves and springs for it
henry J
11-18-2005 15:28:19
 Re: DEERE NOT STARTING in reply to IRON MULE, 11-18-2005 08:03:32
I would even give it a snort of carb cleaner and see if that makes her hit.
I don't think you mentioned if you checked the spark to see if you are getting a nice blue snappy lightening bolt. That is a must.
G/MAN - also...
11-18-2005 10:30:10
Are you 100% sure that the camshaft is correctly timed to the crankshaft?
Kevin L.
11-18-2005 15:18:32
 Re: DEERE NOT STARTING in reply to G/MAN - also..., 11-18-2005 10:30:10
and the distributor is timed right if it turns at the same rate as the camshaft it could be 180 degrees out, if it turns the same rate as the crankshaft then once timed with the flywheel marks, then that's not the problem..
G/MAN
11-18-2005 10:29:08
Make sure you're getting good steady voltage to the ignition system while cranking, and that there's not a bad connection somewhere causing the voltage to drop way off.
