GEAR LUBES
NMI720
11-18-2005 05:34:18
HELLO ALL
AS PART OF MY RESTO ON THE 720D, I AM DRIANG ALL OF THE FLUIDS AND REFILLING. I HAVE THE 1ST REDUCTION COVER FILLED, AND ALL OTHER BOXES ARE EMPTY. WHEN I DRAIN THE FINAL DRIVE/DIFFERENTIAL AREA, IS THAT FILLED BY THE TRANSMISSION OR IS THERE ANDOTHER PLUG. ALSO DOES THE TIMING GEAR HOUSING NEED TO BE FILLED OR IS THAT FILLED WITH THE ENGINE OIL LEVEL. I DO HAVE THE MANUALS, BUT IT DOESNT SAY MUCH ABOUT THESE 2 POINTS. I HAVE ALSO DRAINED THE POWER TROL AND THE PTO CLUTCH HOUSINGS...BUT I LOOKED INT HE BOOK AND FOUND THERE RESPECTIVE FILL PLUGS
Paul_IN
11-20-2005 08:41:04
 Re: GEAR LUBES in reply to NMI720, 11-18-2005 05:34:18
Filling the transmission with gear oil will also take care of the final drive. JD provides two drain plugs because the bottom of the final drive housing is lower than the bolt flange that connects it to the main case. I believe the timing gear cover is filled from the crankcase - I don"t think there is any way to add oil to this without unbolting something big.
NMI720
11-21-2005 06:28:29
 Re: GEAR LUBES in reply to Paul_IN, 11-20-2005 08:41:04
THNAK YOU PAUL. THATS WHAT I THOUGHT...JUST WANTED TO BE SURE
